Electrical question http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=17215 |
Author: | bowfishingnut [ Sat Mar 26, 2011 11:09 am ] |
Post subject: | Electrical question |
I have a 29GTR...Question is this...with the engine running if you disconnect the battery cables should the engine die? I thought the stator would produce enough to run the engine without a battery. Second question...can you install the marine charging system on an older engine? |
Author: | autogateman [ Sat Mar 26, 2011 11:10 am ] |
Post subject: | Re: Electrical question |
1. no it should not die 2.yes but it would probably be expensive. Check with a briggs dealer |
Author: | cb5331 [ Sat Mar 26, 2011 11:14 am ] |
1. Yes, they will die with no battery power. Something about the fuel solenoid or oil something...Either way, I do not believe it will run without battery power unless you bypass something. 2. The stator bolts up differently. You will have to drill and tap the block to fit the new stator. You better have a steady hand, or good luck finding someone to do it for you... |
Author: | bowfishingnut [ Sat Mar 26, 2011 11:20 am ] |
Does someone have a method of testing if the charging system is functioning? Last night my battery died and thank god a brought my charger in the boat with me or I still would be push pollin. |
Author: | cb5331 [ Sat Mar 26, 2011 11:28 am ] |
With the motor running over 2000 rpms, you should be showing somewhere between 13.6-14.4 volts at the battery. It won't be charging while you idle around for bowfishing. |
Author: | bowfishingnut [ Sat Mar 26, 2011 11:32 am ] |
never knew that thanks cb...SO while its at idle it is not charging at all? |
Author: | cb5331 [ Sat Mar 26, 2011 11:37 am ] |
That's the way I understand it. I believe the cdi's have some output at idle, but not the older style. It shouldn't be drawing enough current to kill your battery though, unless you are running lights off the same battery... |
Author: | autogateman [ Sat Mar 26, 2011 11:39 am ] |
the cdi's are 20 amps at idle. it jumps to 50 at a certain rpm, but not sure what rpm it is. |
Author: | Buddman [ Sat Mar 26, 2011 11:40 am ] |
Author: | bowfishingnut [ Sat Mar 26, 2011 4:08 pm ] |
I am not running any full time lights off the battery. Just a deck light to deal with fish when the need arises and my GPS. I need to get a puller to get the flywheel off. I ran it up to 3k and no change in voltage at the battery so I guess it is fried. reg and alt is 150 from BS so might as well just change them out. |
Author: | garrettpearce [ Sat Mar 26, 2011 4:42 pm ] |
i am having the same problem, its probably not the charger they hardly ever go out according to hoyt. first the little plastic plug with two yellow and a red coming out of it cut that off and put butt splices. second someone told me to cut the red wire of the plug and connect it straight to the hot on the starter selanoid |
Author: | garrettpearce [ Sat Mar 26, 2011 4:43 pm ] |
also if it the old style they will run without a battery atleast mine does |
Author: | bowfishingnut [ Sat Mar 26, 2011 5:22 pm ] |
Garrett I do have an electrical connector on the bottom of the carb and when i pull the cable from the battery it will run a couple seconds then die...like it runs out of fuel. I will take a look at the connector...did not think about that one, thanks Me and my boy ended up taking off the belt and clutch assembly(man those bolts were a MF to break loose) while we were working on it today so now my wheels are turning about just installing a cam while I have it down this far and change the belt out. |
Author: | bowfishingnut [ Sat Mar 26, 2011 5:24 pm ] |
what voltage comes out of the alt...and also what is the purpose of the regulator? I assume it regulates the voltage but does anyone know some numbers that I can check with a voltmeter. |
Author: | pooldoo73 [ Sat Mar 26, 2011 8:14 pm ] |
Your voltage won't change when the engine is running. The charger should be producing about 14 volts. The battery will b a little over 13. if you r getting over 14 volts when it is running, u r charging. |
Author: | take'emgator [ Sat Mar 26, 2011 8:46 pm ] |
Wait did you say 29hp GTR? |
Author: | bayouboy [ Sun Mar 27, 2011 12:53 am ] |
The stator should be putting out anywhere from high 30s to 40+ AC volts and the rectifier/voltage regulator converts that to 13 to 14 DC volts. My pigtail shorted out and caught fire so i had to hard wire it back in ( did away with the pigtail and wire crimped the wires together), works great now. also with the big blocks it takes 12 volts to excite the rectifier so the motor will die if the 12volt power source is lost. For instance I have a Mukuni carb ( no fuel shut down solenoid ) and my motor will die everytime I disconnect the battery. |
Author: | Buddman [ Sun Mar 27, 2011 6:26 am ] |
x2 - Mine shut off when unhooked from the battery with the mikuni carb kit |
Author: | bowfishingnut [ Sun Mar 27, 2011 7:13 am ] |
thanks bayouboy thats what i was needing to troubleshoot the problem. take em gator...I bought the motor from a guy who bought the 29hp to build a fan unit and then decided just to bring it to GT and have them install it on a GTR frame so its a bastard GTR. |
Author: | take'emgator [ Sun Mar 27, 2011 8:57 pm ] |
Gotcha, did you get the problem resolved? |
Author: | bowfishingnut [ Mon Mar 28, 2011 6:44 am ] |
No i need to install the clutch and reverse on the back end and then recheck it with a meter. I have always wanted to know how the clutch assembly worked so I took it apart. While GT might have great CS they aint going to get my butt out the marsh in the middle of the night so I better know how to work on this thing. |
Author: | bowfishingnut [ Mon Mar 28, 2011 6:14 pm ] |
put everything back together today and I am reading up to 29v ac from the two yellow wired coming from the alt.. I cranked it up to around 4000rpm but could only get 29v ac. Is the alt still good? Looks like the regulator is dead for sure just not sure of the alt is ok at 29v |
Author: | pokey79 [ Mon Mar 28, 2011 7:33 pm ] |
briggs manuel says at 3600 it should be no less than 26 volts!!!! |
Author: | bowfishingnut [ Tue Mar 29, 2011 6:54 am ] |
Thanks Pokey, I'm going to order just the regulator and give it a shot. |
Author: | Team Camo [ Tue Mar 29, 2011 5:08 pm ] |
My wiring harness plastic connector was bad on my old motor. Sometimes it was charging, sometimes it wasn't. Before spending ya $$ on a stator or a regulator, try cutting out the plastic plugs & butt splicing the wires together. |
Author: | pokey79 [ Tue Mar 29, 2011 5:33 pm ] |
hey before u order the rectifer undo the red wire comin out of the ur rectifer and go straight to the positive side of ur battery or to the hot wire on ur starter and then check the volts at ur battery cause that red wire feeds back to the key switch then back to ur hot side and i have seen that fix ur problem every time i ran in to a charging problem!!!! |
Author: | bowfishingnut [ Tue Mar 29, 2011 6:13 pm ] |
thanks guys i will check those two ideas out tomorrow. That red wire should read 13-14ish vdc while charging correct? |
Author: | pokey79 [ Wed Mar 30, 2011 5:57 pm ] |
yes on the battery!!!! |
Author: | bowfishingnut [ Sun Apr 03, 2011 9:04 pm ] |
thanks again for the help guys...ended up being the regulator was bad. Checked all the connections but was still showing no charge...Changed out reg and all is good now. |
