Which mikuni carb for 32hp generac pd?
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=17737
Author:  browndog1 [ Thu Apr 14, 2011 12:11 am ]
Post subject:  Which mikuni carb for 32hp generac pd?
Looking to put a mikuni carb on a 32hp generac pd, but I can't find any info on the exact model I need. A buddy of mine can do everything needed to mount it, I just need to know which one everyone is running.
thanks
Author:  cb5331 [ Thu Apr 14, 2011 1:13 am ]
Post subject:  Re: Which mikuni carb for 32hp generac pd?
42 hsr...45 would prolly work also, but I believe the 42 is your best option. Call EVT, they should be able to get you the parts you need.
Author:  browndog1 [ Tue Apr 19, 2011 1:46 am ]
Thanks. All of the 42mm mikunis I can find are listed as harley carbs, I'm assuming these are the ones everyone is using? Thinking about buying carb on ebay, but would like to confirm its the right one first.
thanks
Author:  cb5331 [ Tue Apr 19, 2011 5:17 am ]
That is the right carb, but you still need the intake adapter, air filter, throttle cable, boot, etc. I think they change something out on the float, and you will likely need different jets than what it comes with. By the time you buy it all separate, you are better off ordering the carb from EVT. For 415, you get all that stuff with it.
Author:  OwenDickeson [ Tue Apr 19, 2011 8:26 am ]
He will still need an intake adapter.
Author:  cb5331 [ Tue Apr 19, 2011 8:43 am ]
Mine came with it.
