oil sythetic or conventional
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=17906
Author:  Chkmeout [ Wed Apr 20, 2011 8:22 pm ]
Post subject:  oil sythetic or conventional
i just got this boat and just wondering, the guy i bought it from has been running synthetic oil in it , is this ok? should i switch back to convientional ? can i switch back ? i run amsoil synthetic in my duramax and it but not sure on the gator tail ?
Author:  garrettpearce [ Wed Apr 20, 2011 8:23 pm ]
Post subject:  Re: oil sythetic or conventional
i ran royal purple in mine and dint like it. went back to old 30w
Author:  Chkmeout [ Wed Apr 20, 2011 8:24 pm ]
why didnt you like it , personally i would touch royal p but thats me lol
Author:  Woodiebuster [ Wed Apr 20, 2011 8:25 pm ]
Shell 15w-40 and be done with it...
Author:  garrettpearce [ Wed Apr 20, 2011 8:26 pm ]
i found that it made my valves clatter and i looked at it like this i use my motor to crawfish and huntg. it hot sometimes and you need a little thicker oil. im more comfortable with the convential sae 30
Author:  Robn1020 [ Wed Apr 20, 2011 8:27 pm ]
I run royal purple and mine does fine.
Author:  garrettpearce [ Wed Apr 20, 2011 8:28 pm ]
everyone has their own opinion
Author:  deltaduckmaster [ Wed Apr 20, 2011 8:31 pm ]
Stay synthetic
Author:  robertb4wd [ Wed Apr 20, 2011 8:44 pm ]
Mobil 1...
Author:  Chkmeout [ Wed Apr 20, 2011 8:45 pm ]
Author:  drake1 [ Wed Apr 20, 2011 8:58 pm ]
20-50 Amsoil motorcycle oil is what I run.
Author:  Gigafowl [ Wed Apr 20, 2011 8:59 pm ]
Premium 30 like Quaker State or Pennzoil and 1/4 quart of Rizlone
and change it every 20 to 30 hours....
Author:  Team Camo [ Wed Apr 20, 2011 9:02 pm ]
X2 on Mobil 1 & yes it is synthetic. I change mine about every 30 hrs.
Author:  robertb4wd [ Wed Apr 20, 2011 9:27 pm ]
I didn't think any of the synthetic oils broke down?
Author:  MaXXis85 [ Thu Apr 21, 2011 6:05 am ]
Im running Rotella T 15W40 Diesel oil. Yes it is rated for spark ignition aswell. My whole reason of running diesel oil gos back to what 50hptiller refered to about a high zinc oil. High zinc really helps the valve train out in these motors. Oil is a never ending debate. Hell I ran synthetic in my stock powerhead and now run dino diesel oil for my reasons stated...
Facts ABout the only thing BETTER a synthetic will do is LAST LONGER in NORMAL use.
In EXTREME cold sythetic is better for cold flow properties (ie -20* tems)
Extreme heat YES sythetics are better, but an engine will never survive in extreme temps Say 300* oil temps. We can go round and round all day. It is your money so choose the oil you want to spend your money on. For typical use you guys use a dino oil will perform.
If you want to learn about oils go to Bobistheoilguy.com and have at it. You will be amazed at how much the Synthetics are just a waste unless you drastically increase your oil change intervals! Carry on.
Author:  BradS [ Thu Apr 21, 2011 6:13 am ]
Castrol 40 wt --- Im goin to change to the Rotella this oil change for the reasons stated above.
Author:  take'emgator [ Thu Apr 21, 2011 6:30 am ]
Author:  MaXXis85 [ Thu Apr 21, 2011 6:43 am ]
Author:  JIMMY W [ Thu Apr 21, 2011 6:47 am ]
Mobil 1 ;)
Author:  po po mud duck [ Thu Apr 21, 2011 7:19 am ]
I've ran Valvoline VR1 20W/50 for the past 10 years in drag motors with great success.
I didn't want to break the tradition so thats what I'm running in the B&S.
I know guys who run Rotella T 15W/40 in all out gasoline race engines and swear by it. USA Racing in Houston recommends breaking engines in on Rotella T 15W/40.
I agree with MaXXis85, you could debate oil all day long.
50hptiller....Totally agree. I wouldn't run Golden State on my bike chain. :lol:
Author:  WestEndAngler [ Thu Apr 21, 2011 7:20 am ]
Mobil 1 Synthetic & I change it every 15 hours along with my lower unit lube & tranny oil, it take me 15 minutes so why not...
Author:  MaXXis85 [ Thu Apr 21, 2011 7:22 am ]
50HPtiller i see your point, But these motors have an oil pump... Unless it fails you srtill have pressurized oil pumped. I see your point on the splash type oiling systems. Sythetic will have a better film. To each his own. This isnt gonna be a debate, but hey arent we all learning something new?
Author:  BradS [ Thu Apr 21, 2011 8:29 am ]
Author:  robertb4wd [ Thu Apr 21, 2011 8:40 am ]
Just run what you feel comfortable with. My truck, zero turn mower, and boat all take the same oil (5w30). The only odd ball is my atv, it uses 0w40. I've been buying a couple of cases at a time at O'Reilly's. They've been running some sales on Mobil 1 synthetic, $4.99 qt.
Author:  craig [ Thu Apr 21, 2011 9:33 am ]
NO oil will stay together at the temps these engines run. The only REAL solution is to change the oil frequently. VR1 racing oil, amsoil, and rotella 15 w 40 or my picks....with Rotella being at the top.
Author:  Chkmeout [ Thu Apr 21, 2011 10:24 am ]
Is rotella sythetic. ?
Author:  BradS [ Thu Apr 21, 2011 10:34 am ]
No --- its a Diesel oil with a higher zinc level that gas burning oils but is ok to use in gas
Author:  Chkmeout [ Thu Apr 21, 2011 10:37 am ]
Brad is it ok to switch back to conventional if I already use synthetic ? the mods I have need synthetic oil or not ?
Author:  MaXXis85 [ Thu Apr 21, 2011 10:39 am ]
Author:  Chkmeout [ Thu Apr 21, 2011 10:43 am ]
Ok maxis. So the motor has 126 hours. Should I put the rotella t 15-40 in it ? Is that what u use with good success
Author:  JIMMY W [ Thu Apr 21, 2011 12:12 pm ]
Put some Wesson Peanut oil in it :lol:
Author:  Chkmeout [ Thu Apr 21, 2011 12:49 pm ]
Author:  JIMMY W [ Thu Apr 21, 2011 1:55 pm ]
Damn kids :lol:
Author:  Chkmeout [ Thu Apr 21, 2011 2:16 pm ]
Author:  GaugeTheDuckDog [ Thu Apr 21, 2011 9:12 pm ]
Dude just go to the auto parts store and by you some synthetic oil it has 126 hours with no problems it will be fine!
Author:  Robn1020 [ Thu Apr 21, 2011 9:23 pm ]
Author:  Chico80x [ Thu Apr 21, 2011 9:35 pm ]
I run Mobil 1 10w-40 High Mileage. I think any 30 weight oil is too thin for an air cooled engine. Maybe I'm wrong but I still feel better knowing that a 40 weight will hold up better.
Author:  muddiejeep [ Thu Apr 21, 2011 9:45 pm ]
Go to your nearest oil recylcing facility and scoop some oil out of the bin. This will give you a combo of conventional and synthetic. I found through my experience that I wound up with 7w-34, which seems to increase hp for these motors.
J/K Its a lawnmower engine. just change the oil regularly and you will be fine.
Author:  GaugeTheDuckDog [ Thu Apr 21, 2011 9:53 pm ]
Author:  meterman3 [ Thu Apr 21, 2011 11:30 pm ]
10-40 is 10 vis. And the temp and break down of 40 wt
And I drive a pd and approve this message
