benelli08
 Throttle cable tight on mikuni
How to loosen up the stiffness in the throttle cable it won't release back to idle I took it apart and put some WD 40 to loosen it up and it still won't release all the way
_________________ 2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
| Mon Mar 11, 2013 7:32 am |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
 Re: Throttle cable tight on mikuni
Adjustment located on the cable itself is the only thing I can think of.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
| Mon Mar 11, 2013 10:02 am |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
Some cables have an adjustment sleeve on them, some don't. If you don't have it, you have to adjust cable tension by bending the bracket that holds the cable by the poly roller.
Before doing that, are you sure everything else is set right?
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
| Mon Mar 11, 2013 10:14 am |
benelli08
Ill look again when u get home but u dint see any thing to adjust it hate to start bending stuff when I'm not to fimillar with it
| Mon Mar 11, 2013 10:20 am |
Team Camo
Is the cable still tight when throttle is released? If not, then you've got another issue & don't need to adjust cable. If it IS still tight, & you do NOT have the adjustment barrel on the cable, then you'd bend the tab in circled in the pic to adjust tension on the cable.
| Mon Mar 11, 2013 11:41 am |
bbb
| Mon Mar 11, 2013 11:52 am |
benelli08
Ill have to check and see u recently got my boat and motor painted thinking it has something to do with that cause I've had it on there for bout 4 months now and it never have me trouble before I got it painted
| Mon Mar 11, 2013 11:57 am |
Team Camo
Yeah, coulda just got some bad paint. Happens quite often. Try stripping it down & start from scratch again.  j/k
| Mon Mar 11, 2013 12:01 pm |
benelli08
Ya bad paint that's prob the problem. Haha ima have to call camo design tell him to re do it cause my throttle is sticking. Ima mess with it when I get home see if it loosend up Any
| Mon Mar 11, 2013 12:21 pm |
Team Camo
 Ricky would shit!!!
| Mon Mar 11, 2013 12:24 pm |
benelli08
Could that be. A possible problem over spray got On it
| Mon Mar 11, 2013 12:33 pm |
Team Camo
No, more likely he bumped something while taping/masking it off. Probably just a simple adjustment.
| Mon Mar 11, 2013 1:14 pm |
bayouboy
Are you saying that the cable is to short now to release the tension on the carb, or that the cable is binding in cable housing? ( slack at the throttle lever/ grip) . If you have enough length and its not returning it sounds like you might have a broken strand unraveling some where in the housing causing it to bind.
| Mon Mar 11, 2013 1:29 pm |
Kmoppert
Joined: Tue Jun 05, 2012 3:48 pm Posts: 2006 Location: Baton Rouge, LA
_________________ "There's nothing a duck hunter hates more than another duck hunter" ----------------------------------------------------------------------------------------------------------------------------------------------- Custom 17x48 with a new Gen III Prodrive.
| Mon Mar 11, 2013 1:31 pm |
benelli08
I could feel it was real tight when I was running at 1/2 throttle ad when go to accelerate all the way it was very tight and when I got back to landing te cable stayed stuck and it was idling at like 2500 rpm It wouldn't let it release I could t even push it back with my thumb It would never go back all the way but I could always jut push it back with my thumb
| Mon Mar 11, 2013 1:35 pm |
bayouboy
| Mon Mar 11, 2013 1:38 pm |
Team Camo
Yeah, that's a lil different than it just idles too high. There's more info than I was getting.
| Mon Mar 11, 2013 1:52 pm |
benelli08
Prob best I change it
| Mon Mar 11, 2013 2:04 pm |
