It is currently Sat Jul 19, 2025 4:44 am
Reply to topic  [ 9 posts ]
 Tig weldin on muffer
Post Tig weldin on muffer
Have any of yall tryed to tig weld cracks on a muffler?
My EVT is cracking at the bottom where it is clamped into the brace. Wondering if it would be worth it to try to drill each end of the crack and weld it up.
I gave up mud motors
Thu Oct 13, 2011 11:07 am
I weld mine up all the time with 3/32 SS welding rods!!
17x48 extreme stage 2 GTR
Thu Oct 13, 2011 11:12 am
Post Re: Tig weldin on muffer
Mig weld it
1860 center console 36 PD
Duck Down Express
[color=#FFBF00]Team Pro-Drive
Thu Oct 13, 2011 11:21 am
I tig welded my bps muffler after cracking after 20 hours. Now I have over 100 hrs on it without any problems.
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Thu Oct 13, 2011 12:11 pm
Tig it with 316 stainless rods. Drill the holes and take your time with the heat input. Will last longer than the original!
Thu Oct 13, 2011 12:44 pm
i had to tig the stock ss one cause with the mig it was crappy but the aftermarket one might be thicker than the stock!
Thu Oct 13, 2011 1:27 pm
U got little spider cracks all over the bottom right? If so, try to find a piece of thin stainless that u can wrap all the way around it and weld on the edges where the original crimp/weld is. We did this to a buddy of mine after trying to weld all the cracks. The muffler has been heated cooled so much that it is brittle now. The piece we used was .080" or so and has worked out perfect. If u try to Tig it wif 3/32", u gonna blow big holes. We used stainless tie wire with 3/32" tungsten and it was still almost too hot.
18'x54"CC Hanko/ 36PD
Thu Oct 13, 2011 3:24 pm
blow torch and wire coat hanger works wonders.
Thu Oct 13, 2011 3:38 pm
if you can get it clean enough and control the heat so you dont burn the stainless you should be fine, permanent fix would be to plate the bottom of the muffler with stainless and weld the mount back to the plate.
Mon Oct 17, 2011 3:09 pm
Users browsing this forum: No registered users and 87 guests
