It is currently Thu Apr 02, 2026 8:30 pm
Reply to topic  [ 9 posts ]
 Front Battery Mount - issues
Post Front Battery Mount - issues
Rigging out a new hull - and want to mount twin batteries in front of boat
using about 20 feet of primary cable to 35 briggs...
Mfg - warns of 3 problems
1. short in system burning a hole in hull
2. length of cables causing a charging problem on 35 briggs
3. length of cable causing a starter problem on 35 briggs
Question - best type and gauge of cables and way to fuse or circuit break
the primary feed to the motor.... Not so worried about charging the second
battery with the motor as I can do that off generator at the camp or 110
in the driveway....
Eat - Sleep - Hunt ! ! !
Fri Oct 28, 2011 8:30 am
Mine are in the front 16' of cable with no problems. I used #2 S.O. cable (same stuff used for welding leads). The local boat shops here sell high amp circuit breakers
Fri Oct 28, 2011 8:37 am
Post Re: Front Battery Mount - issues
You should run a larger size wire to accomodate the longer run of wire.
Fri Oct 28, 2011 8:41 am
Fri Oct 28, 2011 8:53 am
X2. That's the breakers I was referring to. I went with #2 as the extra cost was minimal.
Fri Oct 28, 2011 9:03 am
Thank - Boat DR - nice to hear it from someone like yourself with
real world practical experience....
Your answers echoed my thoughts but wanted some good input....
Fri Oct 28, 2011 9:37 am
Do away with a battery and starter. 2 less things to break and leave you stranded. You should know that by now.
18x48 Charles Leonard / 36PD
Fri Oct 28, 2011 11:53 am
Post of pics of the new Gatortail hull!
Fri Oct 28, 2011 12:36 pm
your going to want 4/2 AWG Duplex Fine Stranded, Ultra-Flexible, Tinned 105C Copper Boat Cable/Wire. there is a guy on ebay that sells this stuff by the foot for the best price on the net... it also comes joined togther with a protective sleeve to keep sharp edges from cutting into the cable and grounding out...
18x52 Widow Maker Hull being pushed by a HD 5500 BAMF...
Fri Oct 28, 2011 2:15 pm
