It is currently Thu Apr 09, 2026 8:52 pm
Reply to topic  [ 11 posts ]
 18 hp mudbuddy surface drive wont start with key
Post 18 hp mudbuddy surface drive wont start with key
Battery is new. motor will start with the pull rope but all it does when i turn the key over it just clicks. not even offering to turn over. motor has only lke 30 hrs on it. :evil: Does anyone have any ideas what would be wrong?
Sun Oct 23, 2011 6:57 pm
Post Re: 18 hp mudbuddy surface drive wont start with key
Check your electrical connections at the battery and the starter. Probably a loose wire or a build up of corrosion. Make sure you give them a good tug as the connections could be loose inside the terminals.
Sun Oct 23, 2011 7:23 pm
ok ya ill check that out. i hope thats all it is. is there any way that the part that wont let it start unless its out of the water could be bad? idk i had this motor on a 14' john boat and it had a problem starting unless it was at a certain angle. thought that had to do with it not sitting right on the transom. But i just put the motor on a gator trax rogue and it wnt even try to turn over.
Sun Oct 23, 2011 7:59 pm
The mercury switch? It would be easy to bypass so you could rule that out if needed.
Sounds like the solenoid is clicking from what you said in your first post. I believe the mercury switch would keep that from happening. Sounds to me like a bad battery or a bad connection. Your getting enough juice to open the solenoid, just don't have enough to turn the starter. I'd check all your connections first.
Sun Oct 23, 2011 8:02 pm
ok ill give that a shot and get back with you if that doesnt fix it! thanx
Sun Oct 23, 2011 8:23 pm
Not the mercury switch when that goes bad it does nothing no clicks. Either starter is bad or bad electrical connection mine is battery cable needs to be cleaned every so often.
And i would by pass the switch it has solved alot of headaches for me
Mon Oct 24, 2011 8:20 pm
How do I bypass the switch? And does the switch look lk a little black cylinder? Or where is it lol
Tue Oct 25, 2011 8:03 pm
That would be the switch. Just unplug the wires and create a jumper for the connections to run power through
Tue Oct 25, 2011 8:27 pm
Ok I'll try that! Does anyone no where I could get a new starter if that's the case?
Wed Oct 26, 2011 2:58 pm
Unless you've sunk the motor, I doubt you need to replace the starter. They just don't die very often. Have you checked your connections yet? Start with the simple stuff, don't get excited and start repairing and replacing things that weren't broken in the first place.
Wed Oct 26, 2011 3:06 pm
Thanks guys I had a bad cylanoid and now it starts like a champ! I appriciate the help!
Thu Oct 27, 2011 5:14 pm
