dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Upgrade suggestions for batter terminal connections:Video+
I burned the shiat out of my fingers this morning when I tried to tighten the wing nut on my battery terminal. My GTR23 with the decked heads and performance cam requires me to "pump" my starter to turn over the engine to start. This heats up my battery connections. I have one batter (a good one) to which my lights, starter and trim are connected. Do ya'll have recommendations to eliminate this issue...ie terminals and wires getting hot...larger cables, terminal adapters to accommodate multiple connections (right now they're just stacked on top of one another.). Thanks.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Wed Nov 16, 2011 12:59 pm |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
 Re: Upgrade suggestions for batter terminal connections
Terminals shouldn't b getting too hot to touch, no matter how much compression your engine got. U have a connection that is loose. If the cable is crimped to the battery connector u should solder it. U need 2 check the wingnuts often too cause they will loosen up.
_________________ 18'x54"CC Hanko/ 36PD
Wed Nov 16, 2011 2:00 pm |
dguidry
I tighten those mothers as tightly as can be with pliers and they still loosen. I think I'll switch to compression fittings. Here's a picture of my burned thumb.
Wed Nov 16, 2011 2:12 pm |
BoatDR
Wed Nov 16, 2011 2:14 pm |
cb5331
I swear you are fucking retarded. Why didn't you fix this 6 months ago when you started having the problem? You are gonna wear that starter out if you don't fix it. You don't have anywhere near enough compression to put a strain on that starter. It's still a wiring or battery issue, just like it was when you started having problems.
Wed Nov 16, 2011 3:03 pm |
dguidry
Wed Nov 16, 2011 3:31 pm |
dguidry
Wed Nov 16, 2011 5:11 pm |
cb5331
Wed Nov 16, 2011 5:25 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
Hey guidry,Take it to a welding shop and get them to weld that shit to your battery
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
Wed Nov 16, 2011 5:32 pm |
kibb
At least the battery didn't explode in your face.
Wed Nov 16, 2011 5:51 pm |
dguidry
Wed Nov 16, 2011 5:59 pm |
russellm454
Put some blue loctite on the wingnuts. That should keep them from backing off but you have an issue somewhere else if it is takig it that long to fire up. CB come on man you didn't have to call the guy a tard
Wed Nov 16, 2011 6:47 pm |
cb5331
Wed Nov 16, 2011 6:54 pm |
russellm454
Wed Nov 16, 2011 7:11 pm |
JIMMY W
Guidry knows that cb is just giving him a shit!Hunting season makes him mean!
Wed Nov 16, 2011 7:24 pm |
kibb
Don't forget his profession. Don't blame him. Attorneys never admit guilt.
Wed Nov 16, 2011 7:30 pm |
cb5331
Wed Nov 16, 2011 7:38 pm |
dguidry
Cb you have a sick relationship with engines. You care more about how an electrical issue will affect my engine than you do about my burned finger. I think that describes how you relate to most people in your life. Just sayin.. I still like you.
Wed Nov 16, 2011 11:29 pm |
cb5331
Actually, I don't give a shit about your engine or your finger. Just saying we tried to help you with this problem a while back and warned you that bad things could happen. You chose to ignore the help and now you've burned yourself. You burned yourself because you are an idiot.  Why would you think that any one of us care about you burning your finger, anyway?
Thu Nov 17, 2011 10:35 am |
dguidry
Thu Nov 17, 2011 12:14 pm |
cb5331
 Maybe I do care. I think you should be locked in a padded room. That's probably more for other people's saftey than yours though. Guess I still don't give a shit about you.
Thu Nov 17, 2011 1:14 pm |
MaXXis85
Don't let them connections get too hot for cypress knee! wood + heat = Whoooofff
Thu Nov 17, 2011 1:18 pm |
dguidry
Thu Nov 17, 2011 1:28 pm |
dguidry
 Re: Upgrade suggestions for batter terminal connections: UPD
Update photo of my burns
Thu Nov 17, 2011 1:39 pm |
cb5331
Thu Nov 17, 2011 1:41 pm |
MaXXis85
Fuggin water blisters.... Pop them suckas and put some neosporin on dat. DG got your tire fixed?
Thu Nov 17, 2011 1:52 pm |
dguidry
[youtube]http://www.youtube.com/watch?v=AzHfVSRc5sU[/youtube]
Thu Nov 17, 2011 2:06 pm |
dguidry
Thu Nov 17, 2011 2:32 pm |
cb5331
 Re: Upgrade suggestions for batter terminal connections:Vide
 I just noticed the video. You are definitely retarded.
Thu Nov 17, 2011 8:50 pm |
russellm454
Thu Nov 17, 2011 10:08 pm |
WestEndAngler
MMT Moderator
Was he using burnt finger?
Thu Nov 17, 2011 10:32 pm |
dguidry
New terminal connections installed. Problem solved!!! Thanks CB.
Sun Nov 20, 2011 7:48 pm |
cb5331
Now I can sleep at night knowing that you are safe...
Sun Nov 20, 2011 8:07 pm |
