Oil on spark plugs
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=24157
Author:  OwenDickeson [ Fri Nov 18, 2011 9:51 am ]
Post subject:  Oil on spark plugs
Pulled both of my spark plugs and there is a little bit of oil on both of them.
Diagnoses??
Author:  OwenDickeson [ Fri Nov 18, 2011 9:55 am ]
Author:  med [ Fri Nov 18, 2011 10:40 am ]
Post subject:  Re: Oil on spark plugs
Oilyplugosis
Author:  Jamie B. [ Fri Nov 18, 2011 10:44 am ]
When was your last oil change? Are you sure you dont have to much oil in the motor? is your float on your carb stuck?
Ive seen this happen before when the float on a carb was stuck it leaked gas into the oil and created excessive case press and comes through the piston rings. Just a suggestion to check
Author:  Jamie B. [ Fri Nov 18, 2011 10:45 am ]
It also had to much oil in the motor.
Author:  bundy [ Fri Nov 18, 2011 11:56 am ]
prob valve seats
Author:  deadbird8 [ Sat Nov 19, 2011 5:44 am ]
Author:  POKER1 [ Sat Nov 19, 2011 8:41 pm ]
Change your oil and make sure you dont over fill. Run it and see what they look like.
Author:  DeathMetalDukk [ Sat Nov 19, 2011 9:17 pm ]
Has your exhaust been smoking?
Author:  Chico80x [ Sat Nov 19, 2011 9:51 pm ]
How many hours does your engine have? Mine did the same thing while it was breaking in then it went away.
