It is currently Sun Jul 20, 2025 10:00 am
[ 2 posts ] |
AJ
 27 hp kholer gdsd
I have a 27 hp kholer and was wondering where could i get dual exhaust from and if a mikuni carb kit would work for my motor? i am trying to up the motor a bit because it can not push a load at all. thanks
Tue Nov 22, 2011 6:27 pm |
cb5331
 Re: 27 hp kholer gdsd
Only exhaust readily available is the BPS Q. Unless EVT still has some, there is no mikuni kit for them either right now. You do not want a 42 mm carb. If you try to do it, you want the 33mm with the accelerator pump. IMO, heads and exhaust first (also get a velocity stack and k&n for the stock carb)...then cam...then pistons/rods...then carb. If you want to do much more that 2 or 3 of those options, save all your money and put it towards a bigger block.
Tue Nov 22, 2011 6:50 pm |
[ 2 posts ] |
Users browsing this forum: No registered users and 102 guests |
