bubba777
GATOR TAIL VIBRATION
Any body has trouble with there motor vibration very bad threw the rpm range its not a constant vibration the boat is new with 4 hrs on it brought back to gatortail said nothing was wrong with it.. I road in plenty of gatortail that didn't have that much vibration. And for the smart ass people out there no shit they will have vibration.
Mon Feb 13, 2012 7:52 pm |
deltaduckmaster
In what range is the vibration!!
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Mon Feb 13, 2012 7:56 pm |
bubba777
Re: GATOR TAIL VIBRATION
3850 rpm its not constantly it up and down I have a gdsd 35 and it don't vibrate nearly that much. Hoyt check the prop every this is good
Mon Feb 13, 2012 8:02 pm |
deltaduckmaster
Mon Feb 13, 2012 8:19 pm |
deltaduckmaster
Mon Feb 13, 2012 8:20 pm |
eljefe
Joined: Thu Jan 13, 2011 7:32 am Posts: 5210 Location: Beaumont Texas
Trim up some more....or maybe you are trimmed up too far and you just got a light tiller.
_________________ You can't see the sunrise if your eyes are closed. dying aint much of a livin....
Black ops IITX marshstalker
1840 WC www.wccustomboats.com fuel injected 25 GTR
Mon Feb 13, 2012 8:23 pm |
eljefe
Which hole are you in?
Mon Feb 13, 2012 8:24 pm |
Quack Stackin
Joined: Mon Feb 14, 2011 6:07 pm Posts: 759 Location: NE ALABAMA
What kind of load did you have in the boat? And were you WOT?
Mon Feb 13, 2012 8:26 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
Mon Feb 13, 2012 8:28 pm |
bubba777
The pin is the second one and prop half in the water. I was in it with no load I think i might take the motor off and but a rubber gasket on the outside of the transom the boat is noisy with vibration too
Mon Feb 13, 2012 8:31 pm |
bayouboy
Does it do it all the time or just in gear? Did you pull the reverse cover to eliminate the clutch or rev ?
Mon Feb 13, 2012 8:34 pm |
bubba777
Just does in in the water no never took the cover off
Mon Feb 13, 2012 9:00 pm |
Dmstrucks/02
Joined: Tue Mar 29, 2011 2:50 am Posts: 277 Location: La Porte,TX
Mine vibrates when cruising, just figured it was normal. It doesn't resonate through the hull though
_________________ 2012 1860 GT Extreme 35GTR-STOLEN Thanks dik 2013 1860 GT Extreme 35GTR
Tue Feb 14, 2012 3:03 am |
MaXXis85
Tue Feb 14, 2012 7:31 am |
MaXXis85
Pop the cover off the clutch and see if anything looks like it is warped. A good visual of how everything operates will give you a better idea how to diagnose it.
Tue Feb 14, 2012 7:33 am |
bubba777
Thanks for all the help went ride in on of my buddies this morning his does the same thing he had a 1860 extreme i have a 17 54 no extreme i will take the cover off and check as well.
Tue Feb 14, 2012 8:17 am |
deltaduckmaster
In your first post I think you answered your question when you said yes I know they will be vibration!!
Tue Feb 14, 2012 9:05 am |
bubba777
Found the problem gator tail welded up the sides on the floor. And took all vibration out.
Fri Jul 06, 2012 7:45 pm |
Dodgecummins7103
Fri Nov 02, 2018 12:41 am |
