Exhaust gaskets problem
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=27813
Author:  jakecologne [ Tue Mar 20, 2012 9:33 pm ]
Post subject:  Exhaust gaskets problem
I keep blowing my exhaust gaskets out on my 35hp vanguard. I have a x-over exhaust on. Does any know what the problem could be?
Author:  cb5331 [ Tue Mar 20, 2012 9:37 pm ]
Post subject:  Re: Exhaust gaskets problem
Try a thicker gasket.
Author:  jakecologne [ Tue Mar 20, 2012 9:45 pm ]
The thickest that ive found around here just blew out the other day. Let me know or give me a link to more heavy duty ones if you know of some
Author:  cb5331 [ Tue Mar 20, 2012 9:55 pm ]
Post subject:  Re: Re: Exhaust gaskets problem
Author:  jakecologne [ Tue Mar 20, 2012 9:56 pm ]
Thanks
Author:  Beadlejuicejr [ Tue Mar 20, 2012 10:00 pm ]
Flanges maybe warped
Author:  Team Camo [ Tue Mar 20, 2012 10:04 pm ]
I use 2 sets of Briggs gaskets
Sent by carrier pigeon.
Author:  jakecologne [ Tue Mar 20, 2012 10:16 pm ]
Yeah I just changed them again today and put two, I'll see how that works. My exhaust cracked by the flange and when it was welded it was a tad off and had a little slack between the flange gasket and head..could've been the problem
Author:  take'emgator [ Wed Mar 21, 2012 5:10 am ]
Author:  jakecologne [ Wed Mar 21, 2012 12:38 pm ]
Thanks I'll see how 2 gaskets work out
Author:  cb5331 [ Wed Mar 21, 2012 12:54 pm ]
2801 is the size you want. These work well.
http://www.cbperformance.com/catalog.asp?ProductID=519
Author:  CJB [ Wed Mar 21, 2012 1:02 pm ]
Author:  cb5331 [ Wed Mar 21, 2012 1:05 pm ]
Fuck Tony b. I'm tryna get rich! :lol:
Author:  BoatDR [ Wed Mar 21, 2012 1:21 pm ]
Author:  deadbird8 [ Thu Mar 22, 2012 5:52 am ]
Author:  Salty Dawg [ Thu Mar 22, 2012 7:59 am ]
Author:  CJB [ Wed Mar 28, 2012 8:19 pm ]
Just installed brand new second hand EVT on my PD, and I can feel air leaking at the flanges when I crank it up. I doubled up the gasket on one side, because I noticed the gasket still had a little play in it when tight. Well the gasket got tight, but still air leaking through both flanges.
Moral of the story: it looks like I need to order the gaskets mentioned above...
Author:  Salty Dawg [ Wed Mar 28, 2012 8:29 pm ]
Author:  CJB [ Wed Mar 28, 2012 8:43 pm ]
I think I might try to loosen all the bolts on the exhaust and support bracket, then tighten the exhaust flanges first then support bracket second. Maybe the support bracket needs to give a little in order for the flanges to fit tight. I'll check the straightness of the flanges as well
Author:  pooldoo73 [ Thu Mar 29, 2012 8:18 am ]
The flanges on my EVT had to b turned a certain way to bolt up the exhaust.
Author:  cb5331 [ Thu Mar 29, 2012 9:34 am ]
Author:  CJB [ Thu Mar 29, 2012 9:45 am ]
The one I have has the slip flanges. I had to adjust them a little for it to bolt on...
Author:  cb5331 [ Thu Mar 29, 2012 9:53 am ]
Author:  CJB [ Thu Mar 29, 2012 9:55 am ]
Yea you couldn't tell in the pic from that angle. Although I talked to BoatDr and he thinks it may just be the air from the fan blowing down near the exhaust flanges. I need to go run it a while to look for anything black coming from the flanges to determine if there's a leak or not.
Author:  Goose Crumpler [ Thu Mar 29, 2012 3:49 pm ]
Just mix up some real soapy water and spray on while motor is idling. That will tell you right away.
Author:  riverduck [ Mon Jun 29, 2015 9:34 pm ]
Found this old thread. The link above to the 2801 gaskets is no longer working. Anybody know where these gaskets could be found? Thanks!
Author:  Russ [ Mon Jun 29, 2015 9:38 pm ]
Pm or call Boatdr. He'll probably have exactly what you need, or can tell you where to get them. Cb5331 probably knows too and will likely chime in here. If not him, someone will.
Author:  Will [ Tue Jun 30, 2015 4:51 am ]
It's Volkswagen exhaust gasket, I can't find a link for any of the thick compression style now.
Author:  steinb3rg [ Tue Jun 30, 2015 5:17 am ]
If you use the compression type with a stock exhaust, make sure to put a washer or some type of spacer between the stock bracket and the engine block. The thicker gaskets push the exhaust down a little further. I didn't add the washer last time and I put strain on the exhaust flanges causing one to crack
Author:  txmudcutter [ Tue Jun 30, 2015 5:23 am ]
http://www.cbperformance.com/ProductDet ... tCode=2801
Here ya go I just got some about a month ago.
Author:  Buddy [ Tue Jun 30, 2015 9:48 am ]
I have had good luck with the Red High Temp RVT. It got me out of a jam once and haven't been back to regular gaskets yet.
Author:  cb5331 [ Tue Jun 30, 2015 10:53 am ]
These are the one's we use.
Author:  DmaxHunter [ Tue Jun 30, 2015 1:35 pm ]
I've always used stock and never had trouble. Cb why are there 4 per pack, if they collapse, should use one per side. Am I wrong?
Author:  steinb3rg [ Tue Jun 30, 2015 2:07 pm ]
If I'm not mistaken these are for a VW but fit the briggs as well. The VW has four header pipes
Author:  cb5331 [ Tue Jun 30, 2015 2:50 pm ]
Yep...one per side, and a set of spares..
Author:  Gigafowl [ Tue Jun 30, 2015 3:50 pm ]
Good thread - running double gaskets myself.....
