It is currently Sun Jul 20, 2025 1:52 pm
[ 8 posts ] |
Mikuni vacuum... running lean?s
koonce727
Joined: Sat Dec 04, 2010 7:19 pm Posts: 106 Location: Mergens Point, WI
This is a new to me rig so I do not know everything about the set-up. I have about 35hrs on the set-up personally. I noticed white powered on my exhaust tip, turned the motor on and when you get on the throttle you get the classic white smoke. I tryed adjusting the fuel screw and idle but this did not help so i adjusted things back to where they were.
I then noticed when standing in the boat facing the carb that there is a vacuum tube with a rubber cover on the end, the rubber cover is half torn? When I plug it off my idle goes down, and idles just fine, or so it seems, then when you let go(unplug it), the rpms jump up about 400.
I am assuming this may be the cause of my lean issue with the vacuum sucking more air in, but at the same time not sure. Do you guys usually run this vacuum open, or close it off?
Heres a picture of what im talking about.
_________________ Burlap Brothers
Wed Jun 27, 2012 4:29 pm |
50fps
 Re: Mikuni vacuum... running lean?s
Cap it off.
Wed Jun 27, 2012 4:38 pm |
BoatDR
Yes it must be capped.
Wed Jun 27, 2012 4:41 pm |
OwenDickeson
Hmmm... Mine kinda looks like that. lol
Wed Jun 27, 2012 4:43 pm |
koonce727
thanks fellas. Ill be sure to get it capped off.
Wed Jun 27, 2012 4:44 pm |
Dirt17
do you do good on the geese hunting that close to a swing set??
Wed Jun 27, 2012 4:48 pm |
koonce727
Only when Foiles is in town......
Wed Jun 27, 2012 5:09 pm |
cb5331
^nice
Wed Jun 27, 2012 5:23 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 143 guests |
