It is currently Sat Jul 19, 2025 5:25 pm
Reply to topic  [ 11 posts ]
 36 Prodrive clutch issue.
Post 36 Prodrive clutch issue.
How can you tell if the clutch is bad on a 36 Prodrive? Mine has never slipped but today when it got hot from running a long spell in deep water it kept kicking out of drive and acted like it was in neutral. When I let out of the throttle it would kick back in. It got to where it would only stay ingauged at an idle. Any way to test? Adjust? I did notice some fine metallic dust forming on the magnets. Thanks for any help.
36 hp Prodrive pushing a 1648 Alweld
Sun Jun 24, 2012 7:28 am
Post Re: 36 Prodrive clutch issue.
Yeah you can just go on and change it. Mine did the same thing when it was going out.
17/50 GT/HD-MB???
They can run, but in the end they will just die tired.
Sun Jun 24, 2012 9:04 am
Sounds like the PTO switch or possibly a wiring issue to me.
Sun Jun 24, 2012 9:05 am
I checked all wires and none broken, frayed. The switch works great. I don't have to pull it out to make it engage. I just have to let off the gas. When it is hot the top of the clutch rattles and looks to wobble. Is this normal? I haven't had any trouble ever with it slipping. This just started all at once. Any info out there on the cost of the clutch? Do I have to go through Prodrive? Are there any ones better than others? Thanks
Tue Jun 26, 2012 10:11 am
Mine did the same. Changed the switch and never happened again. Good luck to you, hope it's not the clutch.
1748 X-Series pushed by 36PD with MarshMellow Exhaust
Poule Deaux Crew
Wed Jun 27, 2012 1:58 pm
Post Re: Re: 36 Prodrive clutch issue.
Wed Jun 27, 2012 2:10 pm
pull on the 2 wires going into the clutch. the wobble could be your bearing going out but i am gonna go with something electrical
the clutch is about 211.58 after tax
Wed Jun 27, 2012 4:20 pm
Thanks for all of the help. I took a trip UP river yesterday (I've learned my lesson about going down river first) and found my clutch problem. It ended up being the wires going into the clutch like most of you said. The wire was broken where it went into the clutch cover. After pulling in them to get back to the ramp they finially broke off. Looks like a good time to add the reverse since I will be pulling the motor anyway! Any advice on where to buy the clutch? Is Prodrive the only source? Thanks again
Mon Jul 02, 2012 8:51 pm
All you need to replace is the connectors.
Mon Jul 02, 2012 8:53 pm
After getting around to pulling the motor to replace the clutch I also found the noise problem. The wire had broken off smooth with the connector that goes to the magnet. The piece that the motor shaft goes through with the slot for the key way was busted into three pieces but was still holding in there. Don't know how long it had been broke but its been a while cause all of the pieces were worn off round on the ends.
Where is the best place to buy the whole clutch from? Does it have to come from Prodrive? Or is there another brand that is better? Thanks for any help.
Sat Aug 11, 2012 6:01 pm
PD is the only place.
Sat Aug 11, 2012 7:36 pm
Users browsing this forum: No registered users and 120 guests
