It is currently Tue Jul 22, 2025 8:08 am
[ 2 posts ] |
Will busted Stage 2 parts work on stock motor?
willett
Joined: Wed Jan 14, 2009 10:22 am Posts: 1764 Location: Tyler, TX
Few years back I had my 36 Vanguard (non CDI motor) upgraded to Stage 2 by EVT which Included more head work than on stage 1 with new roller rockers, stainless valves, new cam and some other stuff.
Cam shaft sheared or a bolt broke and one the connecting rods broke in the same instance causing the failure.
I still to this day haven't taken everything apart on the busted motor but the top end SHOULD be fine.
I now have a 35 GTR and just got a used PD36 and both are not CDI motors.
Questions:
Are the parts exchangable among the 2 even though one is vertical shaft and other is horizontal?
What parts can I use and will help get better performance out of the motor without going into the bottom end again?
The PD36 does have a small case gasket leak and am going to have break into it at some point, IF i was to do more to the bottom end what is the best cam and other parts to go with now days?
_________________ Pete Willett WC Custom Boats - Tyler, TX http://www.wccustomboats.com
WC Custom 2048 3/16 Bottom Center Console with 35 PD EFI GTR WC Custom 1840 Hybrid 3/16 Bottom with 37 EFI BOSS
Sun Oct 21, 2012 12:29 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
 Re: Will busted Stage 2 parts work on stock motor?
so u said u want to sell the busted pro drive??
Sun Oct 21, 2012 5:18 pm |
[ 2 posts ] |
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 100 guests |
