Full Throttle
Joined: Sun Jan 25, 2009 8:09 pm Posts: 1268 Location: North Texas
Bent Push Rod
What would cause this? I Only have 3 hours on the motor since having a bunch of warranty items completed.
_________________ WC Custom 1854
Fri Oct 26, 2012 8:05 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Re: Bent Push Rod
LAsh set too tight, over revving the motor, depends, but i'm banking on lash set tight
Fri Oct 26, 2012 8:07 pm |
cb5331
Re: Bent Push Rod
Over-rev, but it can get bent if it jumps out of the rocker too, and I'm sure there is other ways as well.
*damn mighty mouse
Fri Oct 26, 2012 8:08 pm |
Full Throttle
Re: Bent Push Rod
It was still connected on the top rocker arm side but out of the seat where it meets the head.
Fri Oct 26, 2012 8:10 pm |
cb5331
Re: Bent Push Rod
Don't worry about it. Just replace it, and keep a close eye on your lash. I check mine at every oil change.
Fri Oct 26, 2012 8:11 pm |
Full Throttle
Re: Bent Push Rod
Cool. I ran it a while back to the boat ramp that way hope it didn't do further damage. My 12 year old is now pretty pissed we are missing the youth opener tomorrow
Fri Oct 26, 2012 8:13 pm |
take'emgator
Re: Bent Push Rod
If it was out of place mostly caused by over reving and vlave lash set to loose, when you replace rod make sure and reset lash. run it a couple of hours and recheck it. should be good to go after that. R
Right back at ya CB lol
cb5331
Re: Bent Push Rod
Where you at? If you aren't too far, you can come borrow one.
Fri Oct 26, 2012 8:14 pm |
take'emgator
Re: Bent Push Rod
set at .005
take'emgator
Re: Bent Push Rod
Fri Oct 26, 2012 8:15 pm |
Full Throttle
Re: Bent Push Rod
Was just joy riding when it happened. Haven't ran it hard or over rev 'd since getting it back. Must have been the valve lash too loose. Thanks for the help
Fri Oct 26, 2012 8:16 pm |
Full Throttle
Re: Bent Push Rod
Fri Oct 26, 2012 8:17 pm |
cb5331
Re: Bent Push Rod
Cool. If you don't find one, gimme a holler. Would suck for the kiddo to miss his whole weekend over something so simple.
Fri Oct 26, 2012 8:21 pm |
Full Throttle
Re: Bent Push Rod
Fri Oct 26, 2012 8:34 pm |
deadbird8
Re: Bent Push Rod
Sat Oct 27, 2012 1:58 am |
