cwb012
spark plugs
whats the best kind of spark plugs for the mud buddy vanguard 45 mag?
Sat Oct 27, 2012 8:35 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Re: spark plugs
champion, NGK
Sat Oct 27, 2012 8:47 pm |
ironman_gq
Re: spark plugs
Agreed, I have had better luck with NGK in most engines but Champions are pretty good. Dont wast money on anything fancy or advertising 20% more power or anything like that. In reality you cannot feel the difference between a standard plug and a $12 plug other than in your wallet when you change them every season.
Mon Oct 29, 2012 1:56 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
Re: spark plugs
I don't know if it's just coincidence or what, but last 3 motors I've seen with fouled plugs were all NGK. I've had best luck with Champion and Autolite
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Mon Oct 29, 2012 3:29 pm |
txmudcutter
Joined: Mon Jan 30, 2012 9:08 am Posts: 2307 Location: Nederland, TX (SETX)
Re: spark plugs
Mon Oct 29, 2012 3:32 pm |
schmitt
Joined: Fri Jun 25, 2010 3:33 pm Posts: 1177 Location: WI
Re: spark plugs
I like champion the best. Seem to get a better read for jetting too
_________________ 1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Mon Oct 29, 2012 3:52 pm |
take'emgator
Re: spark plugs
I run NGK's and haven't had a problem.
Mon Oct 29, 2012 5:42 pm |
take'emgator
Re: spark plugs
Now i will tell you this if they aren't gapped right and 7 times out of 10 right out of the box they are not, then yeah you will see some serious fouling but when gapped right they are great. I ran them in my motor cross bikes which were four stroke
Mon Oct 29, 2012 5:48 pm |
SP
Re: spark plugs
Mon Oct 29, 2012 5:53 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
Re: spark plugs
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
Mon Oct 29, 2012 5:58 pm |
Team Camo
Re: spark plugs
Gapping mine at .30
Mon Oct 29, 2012 6:00 pm |
take'emgator
Re: spark plugs
You can run what ever you want, i found that through my motor those 2 worked the best
Mon Oct 29, 2012 6:11 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
Re: spark plugs
I've been running stock plugs.
Haven't noticed a bit of difference.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Mon Oct 29, 2012 6:15 pm |
The Shafer
Joined: Tue Jan 13, 2009 7:46 pm Posts: 1947 Location: Longview. TX
Re: spark plugs
_________________ WC 1848 Bateau w/ 36 PD FPR
Mon Oct 29, 2012 6:20 pm |
Team Camo
Re: spark plugs
I put new stickers on mine & gained .0896521 mph!!!
Mon Oct 29, 2012 8:07 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
Re: spark plugs
I just spray ether in the carb and it hauls ass and turns some good rpms.
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Mon Oct 29, 2012 8:35 pm |
Beadlejuicejr
Re: spark plugs
But seriously i just run some champions and they fine. It's a spark plug and a Briggs engine it's not rocket science
Mon Oct 29, 2012 8:40 pm |
Buzz Killington
Re: spark plugs
champions are good plugs
x2^^
B. MacDonald
Tue Oct 30, 2012 11:23 am |
cb5331
Re: spark plugs
Autolite 3923's
Tue Oct 30, 2012 12:51 pm |
benelli08
Re: spark plugs
Y'all recommend still using thoes plugs with a highly moded motor
_________________ 2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Tue Oct 30, 2012 1:20 pm |
Team Camo
Re: spark plugs
Yes
Tue Oct 30, 2012 2:00 pm |
barnes_53
Re: spark plugs
Found this on another thread:
Champion-RC14YC NGK-ZFR5F-11 BOSCH-7527 or FR8 DC
gapped at .030
Tue Oct 30, 2012 2:11 pm |
benelli08
Re: spark plugs
Why the Bosch has two diffrent ones
Tue Oct 30, 2012 3:29 pm |
MaXXis85
Re: spark plugs
Electricity will take the path of least resistance. Those fancy multi prong plugs will just mak eyour wallet lighter.
Tue Oct 30, 2012 3:43 pm |
Ruddyduck
Re: spark plugs
Does a 31 use the same plugs mentioned above?
Tue Oct 30, 2012 4:08 pm |
cb5331
Re: spark plugs
My dad runs the app3923's gapped at 35 in his 32 which is the same as your 31. I run them in my 36 as well. Haven't had a lick of trouble out of either motor.
Tue Oct 30, 2012 4:56 pm |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
Re: spark plugs
I have a stock GTR 35 (carb) motor and live in a cold climate. I just changed my plugs to RC14YC's after reading on the Briggs website that they could be better for cold weather starting and after seeing that part number referenced on several maintenance posts here. I gapped them to 0.030.
When I pulled the old plugs I saw they are RC12YC, which is my understanding run colder and help prevent pre-detonation on modded engines.
Would this be a factor in harder starts for cold weather? When would you choose the hotter plug (i.e. what should I be looking for--burned plugs, plugs smelling like gas, etc.)?
Thanks
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
Fri Nov 02, 2018 8:37 am |
Will C
Re: spark plugs
Consider the 14 a small step warmer plug. This does not mean it's a hotter spark. The tip of the spark plug runs a little warmer to keep carbon burned off. Run them and see if they help. It's not much of a heat change from a 12 to a 14
Tue Nov 06, 2018 1:30 am |
MNGunner
Re: spark plugs
Tue Nov 06, 2018 6:36 am |
