bigger prop
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=34859
Author:  Quackhead62 [ Fri Nov 30, 2012 8:17 pm ]
Post subject:  bigger prop
I put a stage one upgrade on my 36 hp Prodrive. I was wondering if it would do more for me to change my prop to a bigger one or a different kind other than the stock one. Any suggestions would be appreciated.
Author:  deadbird8 [ Sat Dec 01, 2012 9:21 am ]
Post subject:  Re: bigger prop
Your question is pretty generic. Depends on the RPM you are running (loaded and unloaded), what you want to achieve (hole shot, top end, RPM reduction), and target RPM you are trying to get to.
Author:  pooldoo73 [ Sat Dec 01, 2012 2:57 pm ]
U have a CDI motor? How big is your boat? Wut Rpms r u running now?
If u do get a different prop, b sure to send it to Peck so he can make sure the taper is cut correctly. Just cost me over $800 to get my entire lower unit rebuilt because I was too smart to send my prop to him first. He still fixed my engine in 1 day and didn't charge me a thing in labor on a 2.5 year old engine.
Author:  indawoods [ Mon Dec 03, 2012 5:44 am ]
Author:  Quackhead62 [ Mon Dec 03, 2012 9:39 am ]
I'm running around 4050 with two people an a dog. No I don't have a CDI motor my motor is a 09. I'd like to add more top end speed my bottom end is good. Cuz I've heard from people that changing from a stock prop helps to gain a little bit more speed
Author:  eljefe [ Mon Dec 03, 2012 9:52 am ]
alot of the speed issue has to deal with the boat its on..........and you can have the pitch worked on your stock prop for cheaper than buying a bigger prop or one with more pitch......more pitch though could mean lower rpms and the same speed.....like I said, a lot of the top end speed has to do with how much boats in the water on plane.......
Author:  deltaduckmaster [ Mon Dec 03, 2012 9:58 am ]
Doesn't do any good to mod a motor to make it turn up more then kill the mods with a bigger prop. You want response load carrying ability and power on the bottom end. Keep the prop stock
Author:  Quackhead62 [ Mon Dec 03, 2012 10:10 am ]
I got yall. I rather have the load carrying abilty an power on the bottom end then just being a lil bit faster
Author:  deadbird8 [ Tue Dec 04, 2012 6:39 am ]
You don't have the RPM room to turn a more aggressive prop. You would have to add other mods and then balance the RPM with a different prop. A more aggressive prop can give great gains on both bottom and top end but you have to have the power to turn it.
Author:  Quackhead62 [ Tue Dec 04, 2012 8:21 am ]
So what do u recommend with a stage one mod. Stay with my stock prop?
Author:  deltaduckmaster [ Tue Dec 04, 2012 8:38 am ]
