It is currently Mon Feb 02, 2026 2:11 pm
Reply to topic  [ 30 posts ]
 MM exhaust broke
Post MM exhaust broke
On the way out yesterday my MM broke. It was a loud SOB. It ran like crap, it was very hard to keep it running at idle, and had some power loss. I'm assuming it was from one of the cylinders not having any back pressure.
Anyone know what kind of warranty the MM have?
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Sun Dec 02, 2012 6:28 pm
Post Re: MM exhaust broke
Give Dan a call. He is top notch about warranty. He will take care of you.
Sun Dec 02, 2012 6:32 pm
Same thing happened to mines...Had it back fixed in 1 week...No charge besides shipping...
Sun Dec 02, 2012 6:36 pm
They junk it won't be the last time it breaks
17x48 extreme stage 2 GTR
Sun Dec 02, 2012 6:57 pm
I can add,,mines is cracked again! Went let my dog out and cover my motor and notice it is cracked again... :(
Sun Dec 02, 2012 7:17 pm
T. Did yours run like shit when it happened?
Sun Dec 02, 2012 7:20 pm
Sun Dec 02, 2012 7:23 pm
Sun Dec 02, 2012 7:39 pm
I had bout 150, got it fixed and got bout 150 more since then and it's cracked again...
Sun Dec 02, 2012 7:46 pm
52 hrs
Sun Dec 02, 2012 7:47 pm
Best thing to do is weld it back with 308 or 309l filler metal. Mine broke at 50 hours due to the welds being poor with little "meat" to them. More than likely it will break again though...
Sun Dec 02, 2012 8:56 pm
This is it. It turns out one of the brackets were broken also. The extra vibration could have had something to do with it.
Mon Dec 03, 2012 9:16 am
A friend of mine had a bracket break on his as well. We just welded it back.
Mon Dec 03, 2012 9:22 am
I'm shipping it back to MM they'll take care of it.
Mon Dec 03, 2012 9:37 am
You can weld it with what ever you want it's gonna Brake on the edge of the weld in the heat affected zone. I fixed mine at least 10 times sent it back got it fixed then it did the same. Had it fixed and traded for a gutted stock.
Mon Dec 03, 2012 9:49 am
What do y'all expect it to be indestructible. They are made out of paper thin crappy stainless, I don't see why people waste time sending them back. Yeah it's getting fixed for free or whatever but it would take less time to drive to a muffler shop and get them to fix it than ship it some where.
Mon Dec 03, 2012 9:57 am
The more times you weld on it the weaker it gets
Mon Dec 03, 2012 10:00 am
Pre-heat and post-heat treatment takes a lot of stress out.
Mon Dec 03, 2012 11:05 am
mines broke in the same spot,,,and a guy i know broke the bracket like that!! Now mines is cracked on the main canister weleded ends, the big end is cracked...
Mon Dec 03, 2012 11:12 am
I tigged the ear on the bracket, back on for a guy. Get them to weld both sides with 309 tig wire. As for that pipe that broke off never seen that.
1754 XSeries Kawi Powered PRODRIVE ...
Mon Dec 03, 2012 3:10 pm
Dont waste your time wif 309. Use Inco 82. 309 is junk wire, a carbon to stainless wire. U need to look into it being a prop change r something else that is causing an unbalanced issue.
18'x54"CC Hanko/ 36PD
Mon Dec 03, 2012 9:11 pm
What is Inco 82?
Tue Dec 04, 2012 6:16 am
I think it was that last rig that blew out in New Iberia.... :lol:
Tue Dec 04, 2012 6:46 am
Tue Dec 04, 2012 6:48 am
Tue Dec 04, 2012 6:50 am
roger dat!
Tue Dec 04, 2012 7:02 am
Inco82 is TIG wire for Inconel. It is also the JB weld of metals. The only way to have a muffler stand up half way desent is to build it out of Inconel or 321 or 347 stainless. Those steels are used for high temp, corrosive enviroments with elevated tensile strength. Inco is way to expensive but 347 or 321 is doable. Last 50 EVT mufflers were done out of 321 but they still made them thin. Need some base metal thickness to make it last.
Tue Dec 04, 2012 3:07 pm
Thanks Drake.
Wed Dec 05, 2012 2:34 pm
Just an FYI: I have a Prodrive 36HP with 42 hours on it. Had issues this past weekend while on a hunt. The baffles inside the exhaust came loose and actually ripped a hole thru the exhaust - broken weld suspected. Obviously this will get replaced under warranty. Believed to be solely due to vibration. Not the only vibration related issues that I have had. Air filter bracket broke, steering rod nut repeatedly loosened until lock tight applied, and sheared bolts on the screen on the flywheel. My brother has extensive knowledge in small engines and is a Certified Master mechanic. He has also spent several hours in the boat with me and was there when the problems are encountered. And, like him, I have spoken to others on these issues - bottom line is, get used to it if you own an "over the transom" mud motor. Exhaust issues seem to be very common. I love the boat package - just have to live with the issues.
Wed Dec 05, 2012 8:52 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest
