It is currently Sat Mar 21, 2026 4:08 pm
Reply to topic  [ 4 posts ]
 PD trim ?
Post PD trim ?
My trim works fine going down, and most of the time well coming up but every now and then it will go real slow up with a lot of whining.
Also is this normal...the fluid that looks to be leaking.ImageUploadedByTapatalk1364013491.102229.jpg
Also this?
1848 ProDrive X Series w/ 36 PD
Fri Mar 22, 2013 10:38 pm
Post Re: PD trim ?
There is a little seap in the line but that may not be enough to matter. Even though the motor charges the battery, if your not running around wide open all the time your battery could be a little weak. Put a charger on you battery and make sure it's fully charged and try it again. It goes down easier due to gravity, it's working to pull it back up. Maybe all it is...
Sat Mar 23, 2013 8:44 am
Post Re: PD trim ?
Thank you
Sat Mar 23, 2013 3:35 pm
Post Re: PD trim ?
check the connections in the switch
I gave up mud motors
Sat Mar 23, 2013 3:42 pm
