Marshmellow exhaust bracket
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=38452
Author:  Quackhead62 [ Thu Mar 07, 2013 9:58 am ]
Post subject:  Marshmellow exhaust bracket
I have a Marsh Mellow double barrel on my PD an I noticed that the bracket that mounts to the motor that supports the motor has a crack in one of the bends. Is that bracket made of Alum or stainless steel? So i know what kind of welding i need to do to fix it. Or is it better to get another bracket from Marsh Mellow?
Author:  CJB [ Thu Mar 07, 2013 10:01 am ]
Post subject:  Re: Marshmellow exhaust bracket
I had the same thing happen. Called Dan at MarshMellow and he sent me two new ones, covered by warranty. Great guy to deal with.
Author:  Quackhead62 [ Thu Mar 07, 2013 10:02 am ]
How long is the Waarranty is good for because i've been having it for a few years
Author:  CJB [ Thu Mar 07, 2013 10:03 am ]
Not sure man, just give him a call and see what he says. I'm sure he'll be willing to help you out either way.
Author:  Quackhead62 [ Thu Mar 07, 2013 10:13 am ]
sounds good to me it's worth a call do you have the number handy
Author:  CJB [ Thu Mar 07, 2013 10:28 am ]
(256) 996-1632 - Dan Horton
Author:  Quackhead62 [ Thu Mar 07, 2013 11:19 am ]
thanks bout to give him a call
Author:  Quackhead62 [ Thu Mar 07, 2013 3:27 pm ]
does it usually take Dan at Marsh Mellow a while to get back to you after you call or e-mail him for some info?
Author:  NFW [ Thu Mar 07, 2013 6:22 pm ]
Yeah mine did the same thing inside bracket i just havent gotten around to it. Do i really need to replace it?
Author:  take'emgator [ Thu Mar 07, 2013 8:32 pm ]
The bracket is stainless steel
Author:  whistlingwings [ Thu Mar 07, 2013 8:44 pm ]
Good luck with that MM exhaust. I've broken every bend on the mounting bracket as well as piping on the muffler itself. Sent it in to MM, got new mounting brackets and the muffler re-welded and I've already had to weld up one break, and have another break that needs tending to.
Author:  Team Camo [ Thu Mar 07, 2013 8:47 pm ]
I replaced a bracket a while back for a customer. Dan takes care of his customers, period. He might charge a few $ for shipping, but he'll make sure you're taken care of. If you called & left a message but didn't get an returned call, try him again tomorrow. He's been crazy busy lately & probably forgot.
WW, are you running it with the diagonal brace on it?
Author:  whistlingwings [ Thu Mar 07, 2013 8:56 pm ]
Author:  Team Camo [ Thu Mar 07, 2013 8:59 pm ]
Try removing the diagonal brace. I've had nothing but good luck without them installed. Like you said, allows it to flex a lil bit instead of cracking.
Author:  Quackhead62 [ Fri Mar 08, 2013 7:42 am ]
thanks for all the good advice i'll give him a call again this morning. an i will also try to take out the diagonal brace when i get the new bracket
Author:  WestEndAngler [ Fri Mar 08, 2013 11:38 am ]
Author:  FowlMouth251 [ Fri Mar 08, 2013 12:20 pm ]
Author:  Quackhead62 [ Fri Mar 08, 2013 6:19 pm ]
No luck again today getting in touch with Dan at Marshmellow about getting a new bracke. Where else can I find a new bracket??
Author:  Calen [ Fri Mar 08, 2013 6:20 pm ]
I should have a few extra ones. Give me a call Monday. I'll send you one
Author:  Quackhead62 [ Fri Mar 08, 2013 7:14 pm ]
Ok I sure will. What is it going to cost me ?
Author:  Calen [ Fri Mar 08, 2013 7:16 pm ]
Shipping
Author:  Quackhead62 [ Fri Mar 08, 2013 7:18 pm ]
Sounds like a deal. I'll give u a call Monday
Author:  FowlMouth251 [ Fri Mar 08, 2013 7:53 pm ]
Author:  Quackhead62 [ Fri Mar 08, 2013 8:18 pm ]
Yea that could be why. I'm just going to get one from Calen since he's not far from me
Author:  JIMMY W [ Fri Mar 08, 2013 8:50 pm ]
Author:  Quackhead62 [ Fri Mar 08, 2013 8:53 pm ]
Yea he does have good customer service. He is the one that did all the mods on my motor
