It is currently Mon Feb 02, 2026 1:22 pm
Reply to topic  [ 29 posts ]
 robin 25 efi mods............................
Post robin 25 efi mods............................
just found this and wanted to get some feed back.... turbo charging a mud motor.....
http://www.ecotrons.com/Small_Engine_RH ... arger.html
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Fri Mar 08, 2013 10:55 am
Post Re: robin 25 efi mods............................
I'm sure it would work. That Subaru engine is built very strong, including a forged steel crank. The naturally aspirated, 720 cc robin advertises 28hp with EFI. With the turbo it should be easy to get well over 40hp, depending on how high you crank the boost. That's the good news. The bad news is I don't know anyone that makes a plug-and-play kit for the conversion. Once you have the turbo it must be mounted and connected to the intake and exhaust. It will probably have to be connected to the engines oil system, also. If you can do a little TIG welding that shouldn't be difficult. The Robin is an "open loop" injection system so you will have to change to larger injectors and probably remap the ECU.
Do you know if the computer software is available to tinker with the Robin ECU? I would like to see you go for it. Your experience might help me if I turbo the 29 Kohler (749cc EFI) or my home built EFI Briggs. In my opinion the Robin lower end and block is stronger than either the Kohler or Briggs, but displacement tops out at 720cc and the Kohler and Briggs big blocks are almost one liter. Displacement provides torque and forced induction is like adding displacement. I have worked with Ecotrons on my EFI Briggs project and have been pleased with both quality and customer service.
Fri Mar 08, 2013 12:51 pm
That would be awesome!
1850 Uncle J
Delta Performance level 4 GTR
Fri Mar 08, 2013 3:52 pm
Jeff, send your block to alaska and let him do it for you! Seems like he could probably make it work, from what i've seen!
1854 InstaGator
35 GTR w/ carb and MM exhaust
"Addicted is an understatement"
*GEAUX TIGERS*
Fri Mar 08, 2013 3:56 pm
Fri Mar 08, 2013 4:45 pm
Fri Mar 08, 2013 6:10 pm
I've been looking at the engine and checking out some of the turbo bikes and carts.....the hardest part looks to be plumbing and brackets....I haven't even looked into the ecu and compatibility but ecotron sells a turbo ready efi system........this is all really beyond me as far as making it work, but it is a possibility for these engines......
sent by carrier pigeon...don't shoot it!!!!
Fri Mar 08, 2013 7:10 pm
Damn what did we say last time we both had an idea like this.....
Oh yea!! I'll do it if you do. :lol:
InstaGator 16.5' x 46" 25efi GTR. Running 30+ SOLD!!!!
dillakilla12 wrote:
I just passed out bc of the blood rush to my penis! Where the fugg can I get a transom like that!?
Fri Mar 08, 2013 11:02 pm
How much boost that thing capable of? A turbo MM would be legit...spool the turbo up some then flip the clutch and nail it prolly get some mud moving.
Fri Mar 08, 2013 11:08 pm
Safely, 5-7 lbs......
Sat Mar 09, 2013 6:54 am
Was really hoping cody would come up with something for the 25, sounded like he was thinking about it. Now he's closed shop. Maybe Calen will come up with some modding ideas.
HOTSAUCE170 wrote:
Sat Mar 09, 2013 7:49 am
I think that if I could spec out everything, this would be the mother of all mods...and i think that the $-hp would be the best value out there.......
Sat Mar 09, 2013 8:02 am
Well do it, test it on yours, and then install on mine and luce's. Thx in advance!:grin:
Sat Mar 09, 2013 8:58 am
Me and Jay already have mod plans in works. If I knew this would work I'd try it too.
Sat Mar 09, 2013 9:02 am
Well you forkers better keep me in the loop. I wanna see what mine is fully capable of.
Sat Mar 09, 2013 9:15 am
It will work, its just being able to apply it to the Subaru....I don't think im tech enough to do it by myself..... it also looks like you would have to change to the turbo ready efi system ecotron sells....
Sat Mar 09, 2013 9:40 am
I think that's gonna end up being the limiting factor on mods on the 25s, the EFI. Somebody needs to figure out a way to tune that system and get more out of it first things first. That way you open the door to being able to play with airflow and compression.
Sat Mar 09, 2013 12:24 pm
Replace subaru efi with ecotrons turbo ready efi.....it has a programmable ecu.
Sat Mar 09, 2013 3:20 pm
Sat Mar 09, 2013 5:26 pm
Makes you wonder what these blocks will handle as far as boost goes. A turbo small engine would have a ridiculous cool factor. Did po po mud duck ever hook his up all the way? I know it looked like he half ass mounted it idk if he ever finished though. Be hard to figure out where to put everything on a MM frame
Sat Mar 09, 2013 5:48 pm
http://youtu.be/b4-tcvSIPEs
Sat Mar 09, 2013 5:50 pm
just got to make sure you get the air fuel right or you'll easlily burn one up, 6K dollar motor ain't worth nothing if you get something wrong and burn it up.
Sat Mar 09, 2013 6:57 pm
Sun Mar 10, 2013 7:57 am
Did po po ever finish the plumbing? Looks like the exhaust is hooked up but not the intake.....
Sun Mar 10, 2013 9:48 am
Sun Mar 10, 2013 10:12 am
Too many hp......they wanted to keep it refuge legal.
Sun Mar 10, 2013 10:15 am
And of I get turbo, torque will be produced.
Sun Mar 10, 2013 10:16 am
Sun Mar 10, 2013 10:20 am
Sun Mar 10, 2013 10:22 am
