It is currently Mon Feb 02, 2026 4:47 pm
Reply to topic  [ 21 posts ]
 Aftermarket parts
Post Aftermarket parts
New to the site and new to mub motor world i have a 36 prodrive with hydraulic reverse and was wondering what other aftermarket products are out there for performance other than bps, marshmellow and mikuni?
Sat Mar 09, 2013 10:26 pm
Post Re: Aftermarket parts
Performance V-Twins
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Mar 09, 2013 10:28 pm
Im gonna have to check them out i want to go stage 1 with it and figured i would start with the exhaust and work my way up
Stock PD36 pushing the shit out of a 19x48 mad man custom boat
Sat Mar 09, 2013 10:50 pm
Peformance V-Twins uses eagle parts, better quality!
Sat Mar 09, 2013 11:00 pm
Exhaust you've got 3 options, gutted stock, MM, or bps "Q" Since you have hydro reverse, I don't recommend MM for you, because you'd need to put a big dent in the bottom can to keep heat off your hydro cylinder. Try the free route 1st, & gut that stocker. If you decide later that you want a MM, I'd be glad to sell you one, but want you to know about the cylinder issue up front.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Mar 09, 2013 11:07 pm
Post Re: aftermarket parts
I thaught about gutting the stock muffler but coming from a mechanic back ground figured it would cause a backfire issue with no baffles ?
Sat Mar 09, 2013 11:17 pm
Meant stock muffler gutted
Sat Mar 09, 2013 11:23 pm
Nope, just makes it louder & breathe better.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Mar 09, 2013 11:29 pm
Thanks for the info team camo cuz im gonna put a k&n air filter on it to help out with intake air flow the noise factor doesnt bother me as much as if it would back fire from not having baffles
Sat Mar 09, 2013 11:39 pm
Can also drill some 1" to 1-1/4" holes in the 4 corners of the metal plate of the breather box to let more airflow in.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Mar 09, 2013 11:47 pm
Sun Mar 10, 2013 1:07 am
Since your right there in Patterson given Calen a call about mods his shop is right there in Franklin
Sun Mar 10, 2013 1:10 am
Sun Mar 10, 2013 1:28 am
Roller Rockers for one
Sun Mar 10, 2013 1:29 am
Sun Mar 10, 2013 2:49 am
Preston, how long have you been using the heat shield, & has it given you ANY issues? Reason I ask is I hate to turn away a customer, but would rather be honest with people & lose a sale, than take their money knowing they're buying something that's just gonna cause them trouble.
Location doesn't show up on Tapatalk. Another vote for Calen.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Mar 10, 2013 3:21 am
I have heard about calen before had a buddy who use to work there plan on doing all mods myself was just curious if there are any other parts brands that wont drain the wallet so much
Sun Mar 10, 2013 9:37 am
Only way to do it cheaper is to DIY. Buy the ss valves & do your own heads, & gut your exhaust. All the cams will cost close to the same. You can piece together a carb kit & save a lil, but do a lot more leg work rounding up parts.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Mar 10, 2013 10:51 am
If you want cheap do as camo said, for the heads get the valves and just bring the heads somewhere to have them shaved and a valve job done. Than just gut the exhaust and buy a cam will be it.
Sun Mar 10, 2013 10:59 am
Thanks for the input do you fellas have any suggestions on where and what type of cam i would need
Sun Mar 10, 2013 11:03 am
Sun Mar 10, 2013 11:50 am
Users browsing this forum: Majestic-12 [Bot] and 2 guests
