Aftermarket parts
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=38537
Author:  Breauxboy84 [ Sat Mar 09, 2013 10:26 pm ]
Post subject:  Aftermarket parts
New to the site and new to mub motor world i have a 36 prodrive with hydraulic reverse and was wondering what other aftermarket products are out there for performance other than bps, marshmellow and mikuni?
Author:  Team Camo [ Sat Mar 09, 2013 10:28 pm ]
Post subject:  Re: Aftermarket parts
Performance V-Twins
Author:  Breauxboy84 [ Sat Mar 09, 2013 10:50 pm ]
Im gonna have to check them out i want to go stage 1 with it and figured i would start with the exhaust and work my way up
Author:  take'emgator [ Sat Mar 09, 2013 11:00 pm ]
Peformance V-Twins uses eagle parts, better quality!
Author:  Team Camo [ Sat Mar 09, 2013 11:07 pm ]
Exhaust you've got 3 options, gutted stock, MM, or bps "Q" Since you have hydro reverse, I don't recommend MM for you, because you'd need to put a big dent in the bottom can to keep heat off your hydro cylinder. Try the free route 1st, & gut that stocker. If you decide later that you want a MM, I'd be glad to sell you one, but want you to know about the cylinder issue up front.
Author:  Breauxboy84 [ Sat Mar 09, 2013 11:17 pm ]
Post subject:  Re: aftermarket parts
I thaught about gutting the stock muffler but coming from a mechanic back ground figured it would cause a backfire issue with no baffles ?
Author:  Breauxboy84 [ Sat Mar 09, 2013 11:23 pm ]
Meant stock muffler gutted
Author:  Team Camo [ Sat Mar 09, 2013 11:29 pm ]
Nope, just makes it louder & breathe better.
Author:  Breauxboy84 [ Sat Mar 09, 2013 11:39 pm ]
Thanks for the info team camo cuz im gonna put a k&n air filter on it to help out with intake air flow the noise factor doesnt bother me as much as if it would back fire from not having baffles
Author:  Team Camo [ Sat Mar 09, 2013 11:47 pm ]
Can also drill some 1" to 1-1/4" holes in the 4 corners of the metal plate of the breather box to let more airflow in.
Author:  deadbird8 [ Sun Mar 10, 2013 1:07 am ]
Author:  Beadlejuicejr [ Sun Mar 10, 2013 1:10 am ]
Since your right there in Patterson given Calen a call about mods his shop is right there in Franklin
Author:  deadbird8 [ Sun Mar 10, 2013 1:28 am ]
Author:  take'emgator [ Sun Mar 10, 2013 1:29 am ]
Roller Rockers for one
Author:  bayouboy [ Sun Mar 10, 2013 2:49 am ]
Author:  Team Camo [ Sun Mar 10, 2013 3:21 am ]
Preston, how long have you been using the heat shield, & has it given you ANY issues? Reason I ask is I hate to turn away a customer, but would rather be honest with people & lose a sale, than take their money knowing they're buying something that's just gonna cause them trouble.
Location doesn't show up on Tapatalk. Another vote for Calen.
Author:  Breauxboy84 [ Sun Mar 10, 2013 9:37 am ]
I have heard about calen before had a buddy who use to work there plan on doing all mods myself was just curious if there are any other parts brands that wont drain the wallet so much
Author:  Team Camo [ Sun Mar 10, 2013 10:51 am ]
Only way to do it cheaper is to DIY. Buy the ss valves & do your own heads, & gut your exhaust. All the cams will cost close to the same. You can piece together a carb kit & save a lil, but do a lot more leg work rounding up parts.
Author:  Beadlejuicejr [ Sun Mar 10, 2013 10:59 am ]
If you want cheap do as camo said, for the heads get the valves and just bring the heads somewhere to have them shaved and a valve job done. Than just gut the exhaust and buy a cam will be it.
Author:  Breauxboy84 [ Sun Mar 10, 2013 11:03 am ]
Thanks for the input do you fellas have any suggestions on where and what type of cam i would need
Author:  bayouboy [ Sun Mar 10, 2013 11:50 am ]
