It is currently Thu Apr 09, 2026 8:41 pm
Reply to topic  [ 18 posts ]
 Throttle cable tight on mikuni
Post Throttle cable tight on mikuni
How to loosen up the stiffness in the throttle cable it won't release back to idle I took it apart and put some WD 40 to loosen it up and it still won't release all the way
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Mon Mar 11, 2013 7:32 am
Post Re: Throttle cable tight on mikuni
Adjustment located on the cable itself is the only thing I can think of.
Mon Mar 11, 2013 10:02 am
Some cables have an adjustment sleeve on them, some don't. If you don't have it, you have to adjust cable tension by bending the bracket that holds the cable by the poly roller.
Before doing that, are you sure everything else is set right?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 11, 2013 10:14 am
Ill look again when u get home but u dint see any thing to adjust it hate to start bending stuff when I'm not to fimillar with it
Mon Mar 11, 2013 10:20 am
Is the cable still tight when throttle is released? If not, then you've got another issue & don't need to adjust cable. If it IS still tight, & you do NOT have the adjustment barrel on the cable, then you'd bend the tab in circled in the pic to adjust tension on the cable.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 11, 2013 11:41 am
Mon Mar 11, 2013 11:52 am
Ill have to check and see u recently got my boat and motor painted thinking it has something to do with that cause I've had it on there for bout 4 months now and it never have me trouble before I got it painted
Mon Mar 11, 2013 11:57 am
Yeah, coulda just got some bad paint. Happens quite often. Try stripping it down & start from scratch again.
:lol: j/k
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 11, 2013 12:01 pm
Ya bad paint that's prob the problem. Haha ima have to call camo design tell him to re do it cause my throttle is sticking.
Ima mess with it when I get home see if it loosend up
Any
Mon Mar 11, 2013 12:21 pm
:lol: Ricky would shit!!!
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 11, 2013 12:24 pm
Could that be. A possible problem over spray got
On it
Mon Mar 11, 2013 12:33 pm
No, more likely he bumped something while taping/masking it off. Probably just a simple adjustment.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 11, 2013 1:14 pm
Are you saying that the cable is to short now to release the tension on the carb, or that the cable is binding in cable housing? ( slack at the throttle lever/ grip) . If you have enough length and its not returning it sounds like you might have a broken strand unraveling some where in the housing causing it to bind.
Mon Mar 11, 2013 1:29 pm
"There's nothing a duck hunter hates more than another duck hunter"
Custom 17x48 with a new Gen III Prodrive.
Mon Mar 11, 2013 1:31 pm
I could feel it was real tight when I was running at 1/2 throttle ad when go to accelerate all the way it was very tight and when I got back to landing te cable stayed stuck and it was idling at like 2500 rpm
It wouldn't let it release I could t even push it back with my thumb
It would never go back all the way but I could always jut push it back with my thumb
Mon Mar 11, 2013 1:35 pm
Mon Mar 11, 2013 1:38 pm
Yeah, that's a lil different than it just idles too high. There's more info than I was getting.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Mar 11, 2013 1:52 pm
Prob best I change it
Mon Mar 11, 2013 2:04 pm
