CZECHHOME
Joined: Sat Feb 02, 2013 5:57 pm Posts: 341 Location: RALEIGH NC
 rpm
Ok I looked but could not find what I was looking for I done a up grade on a 36 prodrive head cam piston carb ect.
The rpms are 1200 in neutral and 1100 in gear and tops out at 4200 is that good ?
I was thinking getting 4700 rev limiter rpm but It took all I could to get it to hit the factory rev limiter. Is this normal ? The speeds are one guy 30 two 25 THANKS FOR ANY HELP
Sun Apr 14, 2013 5:56 am |
DUCK HEARSE
Joined: Fri Apr 06, 2012 8:48 am Posts: 3161 Location: Alabama
 Re: rpm
something is wrong with those mods you should be running better than that.
_________________ Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. - Mark Twain
Sun Apr 14, 2013 8:30 am |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
 Re: rpm
How was your trim. That has a lot to do with it. I run 4650 no problem with the mods I have even with a load and new prop.
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
Sun Apr 14, 2013 8:35 am |
OwenDickeson
 Re: rpm
Something isn't set right. I could turn 4600 with a load with heads, cam, carb, and exhaust.
Sun Apr 14, 2013 8:48 am |
PSD
 Re: rpm
I have a stage one and I am all over 4700 rev limit. So you should be doing way better than that with those mods
Sun Apr 14, 2013 8:57 am |
CZECHHOME
 Re: rpm
I don't have the best boat 1854 f 86 excel . The motor still has the factory rev It kick in around 4300 right? I cant make it hit that trim up but the throttle is all the way , It has new prop , Maybe I messed up on the numbers. I going to take it out again and redo it what numbers are good with the factory rev thanks sorry for all the ??
Sun Apr 14, 2013 11:27 am |
PSD
 Re: rpm
Does it have the high rev coils on it ???
Sun Apr 14, 2013 3:10 pm |
CZECHHOME
 Re: rpm
NO it a 2012 I am going to call Andy with the boat doc and order it . I just don't think it would get to a higher rpm .
Sun Apr 14, 2013 3:25 pm |
jerimiahw
Joined: Sun Sep 23, 2012 8:10 pm Posts: 1191 Location: chauvin
 Re: rpm
I have cam heads and carb mods by setx and turn 4700 with four people
Sun Apr 14, 2013 8:49 pm |
jerimiahw
 Re: rpm
U should be able to run 32 with two people I run a 18/54 and have no problem hitting rev limiter
Sun Apr 14, 2013 8:53 pm |
deadbird8
 Re: rpm
You sure your governor is locked out maxed? Something is wrong if you can't get over 4300.
I have an 1851 Excel and ran 4300 with 5 people with a hammer prop this weekend.
Mon Apr 15, 2013 8:24 pm |
