| 36 pro drive oil capacity? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=38944 |
| Author: | Alex6528 [ Thu Mar 21, 2013 4:16 pm ] |
| Post subject: | 36 pro drive oil capacity? |
What is the oil capacity for a 36 pd? The engine owners manual says something like 70-84 ounces, but doesn't specify what model requires how much. I know the pd maintenance thread says 2 qts, but that's less than what the manual says. Also I'm thinking sae 30 for the hot summer, and 10w-30 for the winter once it cools off. |
| Author: | cb5331 [ Thu Mar 21, 2013 4:27 pm ] |
| Post subject: | Re: 36 pro drive oil capacity? |
You will never get all the oil out of the motor. I usually drain it, fill it with about 1 3/4 qts, check the dipstick, then run it for a few minutes, and check again. I keep mine just above the add line. You do not want to overfill it! |
| Author: | Will [ Thu Mar 21, 2013 5:03 pm ] |
If i drain mine and put 2 quarts in, it's right on the add mark after running for a minute. 5w 30 in mine... |
