BrackIV
Joined: Sat Nov 21, 2009 8:58 pm Posts: 641 Location: SETX
 GTR dying when trimmed up ??
Just installed a fuel/water separator. Ran perfectly before install. Now motor dies when trimed up to get rooster tail. Is my fuel pump not strong enough to pull through filter? I can run half throttle trimmed down and everything is fine. Trim up and open her up, she dies..
_________________ 1854 InstaGator 35 GTR w/ carb and MM exhaust
"Addicted is an understatement" *GEAUX TIGERS*
| Fri Mar 22, 2013 11:59 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: GTR dying when trimmed up ??
Did you check everything like we talked about? Find anything?
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
| Sun Mar 24, 2013 1:01 am |
cajuncoon
Joined: Sun Oct 17, 2010 9:24 pm Posts: 89 Location: golden meadow la.
ive got the large fuel water seperator on a gator tail my tank is all the way in the front of my boat, got the larger carb, heads and cam with no probs. should not be that. must be sucking air somewhere.
_________________ 1754 southfork with hopkins prop on moded gtr
| Sun Mar 24, 2013 9:50 am |
BrackIV
I bypassed my separator and had zero problems. I have 24' of 5/16" fuel line. What was weird was that it would only die when I trimmed it up. If I ran it sub surface, it didn't die
| Sun Mar 24, 2013 12:18 pm |
Team Camo
Leaking fitting or plug on the F/W separator. Will's was giving us a fit trying to tune his motor, replaced it (because fittings were stripping off) & unhooked his e-pump, now he's got zero problems. Make sure everything is good & tight so it's sealing off.
| Sun Mar 24, 2013 12:25 pm |
BrackIV
| Sun Mar 24, 2013 12:33 pm |
Will
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Sun Mar 24, 2013 4:39 pm |
