| PD trim ? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=38978 |
| Author: | wacknstack [ Fri Mar 22, 2013 10:38 pm ] |
| Post subject: | PD trim ? |
My trim works fine going down, and most of the time well coming up but every now and then it will go real slow up with a lot of whining. Also is this normal...the fluid that looks to be leaking.ImageUploadedByTapatalk1364013491.102229.jpg Also this? ImageUploadedByTapatalk1364013514.669065.jpg |
| Author: | Will [ Sat Mar 23, 2013 8:44 am ] |
| Post subject: | Re: PD trim ? |
There is a little seap in the line but that may not be enough to matter. Even though the motor charges the battery, if your not running around wide open all the time your battery could be a little weak. Put a charger on you battery and make sure it's fully charged and try it again. It goes down easier due to gravity, it's working to pull it back up. Maybe all it is... |
| Author: | wacknstack [ Sat Mar 23, 2013 3:35 pm ] |
Thank you |
| Author: | T-Bubba [ Sat Mar 23, 2013 3:42 pm ] |
check the connections in the switch |
