GTR dying when trimmed up ??
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=38979
Author:  BrackIV [ Fri Mar 22, 2013 11:59 pm ]
Post subject:  GTR dying when trimmed up ??
Just installed a fuel/water separator. Ran perfectly before install. Now motor dies when trimed up to get rooster tail. Is my fuel pump not strong enough to pull through filter? I can run half throttle trimmed down and everything is fine. Trim up and open her up, she dies..
Author:  Team Camo [ Sun Mar 24, 2013 1:01 am ]
Post subject:  Re: GTR dying when trimmed up ??
Did you check everything like we talked about? Find anything?
Author:  cajuncoon [ Sun Mar 24, 2013 9:50 am ]
ive got the large fuel water seperator on a gator tail my tank is all the way in the front of my boat, got the larger carb, heads and cam with no probs. should not be that. must be sucking air somewhere.
Author:  BrackIV [ Sun Mar 24, 2013 12:18 pm ]
I bypassed my separator and had zero problems. I have 24' of 5/16" fuel line. What was weird was that it would only die when I trimmed it up. If I ran it sub surface, it didn't die
Author:  Team Camo [ Sun Mar 24, 2013 12:25 pm ]
Leaking fitting or plug on the F/W separator. Will's was giving us a fit trying to tune his motor, replaced it (because fittings were stripping off) & unhooked his e-pump, now he's got zero problems. Make sure everything is good & tight so it's sealing off.
Author:  BrackIV [ Sun Mar 24, 2013 12:33 pm ]
Author:  Will [ Sun Mar 24, 2013 4:39 pm ]
