It is currently Tue Dec 16, 2025 7:05 am
Reply to topic  [ 4 posts ]
 Rpm at idle
Post Rpm at idle
What rpms should i have at idle ? Mine is running around 1600 in neutral and around 1250 to 1300 in gear? Its at 2013 35 GTR
My old motor idled around 1250 in neutral and 1050 to 1100 in gear.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
1854 GTB Extreme 35GTR
Tue Apr 02, 2013 1:56 pm
Post Re: Rim at idle
Idle it down and play with the pilot air mixture screws. You can pretty much set it as low as you can get it to stay running, just takes a little time. Mines at around 1000 out of gear and 800 in gear.
Tue Apr 02, 2013 2:02 pm
Post Re: Rpm at idle
CDI will allow you to idle lower than stock coils. 1000 to 1100 is fine
Wed Apr 03, 2013 6:54 pm
I adjusted down to 1300 rpms at idle. The only problem is when I give it throttle and it comes back to idle it seems to idle higher than what I just set it at. This is all in neutral also
Wed Apr 03, 2013 7:03 pm
