It is currently Fri Dec 19, 2025 5:25 pm
Reply to topic  [ 22 posts ]
 Thinking of adding cam
Post Thinking of adding cam
Thinking of adding cam to my bd5500 just wondering what a difference it would make?
Tue Apr 02, 2013 4:23 pm
Post Re: Thinking of adding cam
What other work is done to the motor?
Tue Apr 02, 2013 4:25 pm
Just heads carbs and high rev coils
Tue Apr 02, 2013 4:30 pm
Has exhaust also
Tue Apr 02, 2013 4:31 pm
Might gain 1-2mph on top end. Load carrying is where the can will shine.
Tue Apr 02, 2013 4:43 pm
I can't turn but 4700 rpm's had 4 people in the boat this weekend turning 4600 just don't know if i really need it
Tue Apr 02, 2013 6:33 pm
What were your speeds running with 4 people?
Tue Apr 02, 2013 7:04 pm
Not sure didn't GPS it but it wasn't slow at all I'm thinking at least 29 or 30
Tue Apr 02, 2013 7:12 pm
If you're running that without a can I wouldn't really worry about adding a cam unless you are struggling to get on plane.
Tue Apr 02, 2013 9:59 pm
- Mark Twain
Wed Apr 03, 2013 6:08 am
Thanks guys im running 40 47 gears would a 46 bottom make any more speed?
Wed Apr 03, 2013 6:48 am
Thu Apr 04, 2013 4:55 am
Thu Apr 04, 2013 5:05 am
40/47 gears?
If you turning 4700 with those gears running 30mph, your getting a whopping 28% slippage. So either your prop is wore out or your over trimming.
Gear down, check prop/ trim height. And watch load carrying increase, acceleration, and top speed. Put the cam if you ain't happy.
Thu Apr 04, 2013 6:18 am
^ Did Cody rejoin or did someone steal his username?
Thu Apr 04, 2013 6:31 am
16.5' x 46" Instagator w/25GTRRRR
SetxPerformanceshop.com or (409)548-4477
Thu Apr 04, 2013 7:28 am
I'm running the hammer prop now ran it with GPS yesterday 3 guys 1-150 2-200 got 33 mph in the sweet spot at 4580 to 4600 had the prop a while does have some slight wear but not much
Thu Apr 04, 2013 7:59 am
1848 ProDrive X Series w/ 36 PD
Thu Apr 04, 2013 8:05 am
Thu Apr 04, 2013 8:08 am
Fri Apr 05, 2013 9:50 pm
Fri Apr 05, 2013 9:54 pm
Fri Apr 05, 2013 10:26 pm
