med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
Re: 35 GTR clutch cover
Wheres the slot to put the quarters in to get the condom? Sent from my DROIDX using Tapatalk 2
_________________ 1850 & 36pd
Fri Aug 23, 2013 4:07 pm |
Bigrich
Joined: Wed Dec 19, 2012 7:52 pm Posts: 7064 Location: Mallard country
Fri Aug 23, 2013 4:20 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Fri Aug 23, 2013 8:52 pm |
med
Sat Aug 24, 2013 2:13 am |
take'emgator
I'm coming through Lafayette tomorrow to around the new I Eric area if u guys wan one I'll carry some with me
Sun Aug 25, 2013 5:27 pm |
take'emgator
Sorry New Iberia area*
prodrivinggatortail
NOT THE NEW COVER'S FAULT.
But has anyone had the bolt strip out of the aluminum part that you screw the bolt in after changing cover, leaving the cover hanging by only one bolt, and just waiting to go swimming? If so I have fixed that and it is back like it was from the factory. Will post a picture later if some are interested. Don't want to waste space if I am the only one worried about losing a cover, because of a stripped bolt.
Thu Sep 12, 2013 12:32 pm |
Bigrich
Sure post pic someone else might have same issue one day
Thu Sep 12, 2013 2:01 pm |
rob_E
Joined: Wed Jan 25, 2012 12:03 pm Posts: 1763 Location: Prairieville, LA
here is a pic of my new clutch cover with a custom rattle can paint job. Mine was realy tough to get on because the evt was in the way and I will need to get some longer bolts add some washers or something because the nuts are a ilttle to small but Im real happy with how it looks. Thanks Justin
_________________ 18X54 CC & 35 GTR w/ Hoyts Stage 1
Tue Sep 17, 2013 8:32 am |
prodrivinggatortail
It can still be put on with studs sticking out of the GTR housing, but it will take a little more effort to put on and off. First you have to remove the original factory bolts and install studs from the inside coming out. The studs I used are the ones that you can put an allen wrench on one end( A special name for them but I don't know it). On the end which screws in from the inside of the housing I double nutted 2 nuts together on the stud and even used red loctite on it as an overkill. To put the cover on, you have to use the allen wrench to back the stud back into the housing, allowing the cover to slide on. Then after the cover is in place, using the allen wrench just screw the stud into the GTR housing, causing it to stick out of the cover. Tighten the stud against the GTR housing, then put flat washer and lock nut on the stud and tighten the lock nut. When you want to take cover off, you will have to back the stud back into the housing with the allen wrench again, but it is on just like it was from the factory. Oh and I also JB Welded a 1/4"x1" flat bar along the right side of the housing, so it would fill in the space between the 2 housings. In picture you can see the stud I used.
Tue Sep 17, 2013 9:15 am |
rob_E
Thanks PG thats what im going to do. Does anyone know what they call those studs.
Tue Sep 17, 2013 9:55 am |
prodrivinggatortail
Rob, I got curious and went looking. It is called a Grub screw http://www.google.com/imgres?imgurl=htt ... Q&dur=1062
Tue Sep 17, 2013 10:20 am |
rob_E
thanks
Tue Sep 17, 2013 10:56 am |
luckyhat12
Joined: Thu Dec 08, 2011 5:50 pm Posts: 30 Location: DFW
I know this is an old thread... but for those of you making or that have made the aluminum covers, how thick is the aluminum you are using and what grade?
I have a hobby grade spool gun for my hobart 210MVP mig and I'm about to buy some gas in the next week or three to start playing. I have the 3rd gen GTR that no one seems to make a cover for so I'm going to try and make one for myself. I'd do the bolt together version honestly, but I still need to know what kind of metal you guys used even for that one.
I don't have a bender so it will be challenging to use something too heavy. I'll probably bold down some angle to my metal table and make the straight bends best I can without a brake.
This thread just seemed to make the most sense to post the question into.
Thanks for the help
_________________ 2054 WC Custom CC pushed by a GTR
Mon Jul 24, 2017 12:03 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
If your going to brake it you will need 5052. 1/8" will work fine.
Mon Jul 24, 2017 12:56 pm |
luckyhat12
Thanks North LA Hunter..... I took some thin aluminum and cut some pieces for the inside and outside this weekend and riveted them through to hold for a while longer till the other side breaks. After that.... I'm going to have to go back to work.
On my motor, it looks like the motor may be cocked just a little bit because the brake rotor is a bit proud of flush on the port side.... it will require adjusting and some flare to clear the rotor. I'm thinking that the adjustment will happen anyway now that I know about it.
Appreciate the help fellas.
Sun Jul 30, 2017 7:37 pm |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
Go on down to the hardware store and buy ya self a mail box. Hard wheel grind half of it off. Preferably the back half leave the door, mount it up on der. Then you've got an access door for adjustments and such.
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
Mon Jul 31, 2017 1:10 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
F yes, better than plastic.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Mon Jul 31, 2017 1:26 pm |
luckyhat12
Tue Aug 08, 2017 2:31 pm |
