It is currently Fri Jul 04, 2025 9:57 am
Reply to topic  [ 9 posts ]
 Gatortail Fuel Pump
Post Gatortail Fuel Pump
Is there any good reason to keep the vacuum operated fuel pump on a gatortail if you are adding an electric ful pump in line? 2 fuel pumps????
Wed Apr 10, 2013 7:45 am
Post Re: Gatortail Fuel Pump
No reason to put a electric fuel pump on one!Are you having fuel problems?
Wed Apr 10, 2013 8:27 am
No problems, Just saw all the ones from gatortail with Mikuni carbs and mods having electric pumps. and I happen to have a new electric fuel pump at the house not being used
Wed Apr 10, 2013 8:49 am
Buddy was using an e pump, was burning 2x the amount of fuel. It was the lower psi mr gasket
Wed Apr 10, 2013 8:54 am
Was the fuel just coming out the overflow? My buddy has the same set up as me with the E pump and the vacuum pump and get really good milage. But it sounds like there is no advantage to keeping both pumps in line.
Wed Apr 10, 2013 8:57 am
E-pump is a waste of $ most of the time. You're better off fixing you leaking fuel line than adding e-pump.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Apr 10, 2013 9:37 am
I installed a larger fuel line to solve my problems and a larger fuel filter and to be honest I think it may have been the carb that was causing the problems. due to ethanol... Adding anything else electronic that can break is just a bad idea imho.
The amount of fuel that that mechanical fuel pump delivers at WOT is probably enough to run a 350 Chevy motor...
Wed Apr 10, 2013 10:08 am
Wed Apr 10, 2013 11:10 am
Wed Apr 10, 2013 8:05 pm
Users browsing this forum: No registered users and 112 guests
