It is currently Wed Apr 01, 2026 8:39 am
Reply to topic  [ 4 posts ]
 Honda gx630 kill switch
Post Honda gx630 kill switch
Swapped out my 16 vanguard on my gd for a new gx630 honda. Swap was easy, everything lined up, shaft is centered and is giving off less heat than the 16 was. Now the problem. The only place I can find to link the kill switch is the low oil shut off. I'm not an electrician. When I piggyback them together the kill switch works as it should. My question is am I going to do any harm to the electrical system by linking them together?? I would think it would be no different than the low oil sensor shutting the motor. down? I hope to never have to use the kill tether, but don't dare run it with out it. Thanks for any input.
Sun Apr 28, 2013 2:07 pm
Post Re: Honda gx630 kill switch
I think you'll be fine
If it warrants any more discussion I can pull a print for my gx670 should be really close
Sun Apr 28, 2013 2:28 pm
^^^^ Thanks!^^^^
Sun Apr 28, 2013 3:06 pm
I found that electrical print if you want a copy of it
Hit me with a pm of email or cell #
Mon Apr 29, 2013 7:42 pm
