| Anti sieze on exhaust bolts http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=40707 |
| Author: | dirtybird29+ [ Mon May 13, 2013 9:35 am ] |
| Post subject: | Anti sieze on exhaust bolts |
How many of y'all are using anti sieze on exhaust bolts when installing new exhaust? Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 |
| Author: | SCmudder7071 [ Mon May 13, 2013 9:40 am ] |
| Post subject: | Re: Anti sieze on exhaust bolts |
I don't |
| Author: | renovator [ Mon May 13, 2013 1:18 pm ] |
I put locktite on mine |
| Author: | missile [ Mon May 13, 2013 2:25 pm ] |
i put it on mine but they will not stay tight now. |
| Author: | bayouboy [ Mon May 13, 2013 2:44 pm ] |
To hell with bolts! use studs and nuts, you'll double your chances of getting your exhaust off with out breaking something! |
| Author: | duckmedic269 [ Mon May 13, 2013 3:37 pm ] |
What size ? That sounds like a pretty good idea |
| Author: | JLACOUR [ Mon May 13, 2013 3:42 pm ] |
| Author: | med [ Mon May 13, 2013 3:51 pm ] |
| Author: | bayouboy [ Mon May 13, 2013 4:09 pm ] |
M8 X 1.25 x 40mm long. Might check with the boat Dr, They were known for selling them. They have an allen insert on one end so that you can hold it from turning. |
| Author: | bayouboy [ Mon May 13, 2013 4:28 pm ] |
Here is a 7 piece set on Ebay ( good to have and extra just in case you do loose one). And look it even comes with never-sieze! lol http://www.ebay.com/itm/7-Piece-M8-x-1- ... 8072372%26 |
| Author: | banded-mallard [ Tue May 14, 2013 5:17 am ] |
| Author: | bayouboy [ Tue May 14, 2013 11:26 am ] |
Yep |
| Author: | banded-mallard [ Tue May 14, 2013 11:28 am ] |
Did you loctite the threads, or what keeps the nuts from backing off? Bout to pull block and change gasket and that looks like a viable option. |
| Author: | bayouboy [ Tue May 14, 2013 1:17 pm ] |
| Author: | Ender [ Tue May 14, 2013 3:01 pm ] |
Anti-seize with drilled bolt heads and safety wire. |
| Author: | quackconsumer [ Wed May 15, 2013 5:13 am ] |
Preston, did you helicoil it before putting those studs in? |
| Author: | renovator [ Wed May 15, 2013 5:52 am ] |
I may go this route the next time the exhaust comes off. It a bps so it will be back off in 20 or so hours to be welded again. |
| Author: | Will [ Wed May 15, 2013 5:58 am ] |
