Will
 Cut plate to remove PD motor and clutch?
Has anyone cut the plate on a tiller enough to pull the motor and clutch without having to pull the entire assembly, handle and all? Got to pull it all, remove the clutch and then remove the motor from the plate. Seems it would save time if you could just disconnect power, ground and gas and pull motor and clutch...
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Mon May 13, 2013 3:55 pm |
OwenDickeson
 Re: Cut plate to remove PD motor and clutch?
So you want to cut a hole big enough in the top plate for the clutch to fit through?
| Mon May 13, 2013 5:19 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
What ya got going on?
_________________ 1850 & 36pd
| Mon May 13, 2013 5:22 pm |
Will
Yea, thinking about it... Cutting a new one first if nobody's tried it before.
| Mon May 13, 2013 5:23 pm |
Will
Case gasket is bad enough im adding oil now. Pulled it yesterday and noticed what you gotta go through...
| Mon May 13, 2013 5:24 pm |
banded-mallard
The more I looked at the hundred pics you sent me, the more I think it will work. The only thing that is in the back of my mind is once the hole is cut, would it put stress on these spots with the motor torque. IMG_1862.JPG IMG_1862-1.jpg But like you said, when I pull my block, might fire up the miller and cut a bigger hole in that bitch.
| Tue May 14, 2013 5:07 am |
Will
Worth a shot, could always replace that plate if it don't work. Lots of things are overkill when it comes to strength, maybe this is one of them and I'm sure PD has tried it, or maybe not. It would be easier not to mess with everything if you just want to work on the power head.
| Tue May 14, 2013 5:17 am |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
You still have to remove the clutch to replace the case gasket
_________________ You have your whole life to be an idiot, take a day off!
| Tue May 14, 2013 5:43 am |
Will
| Tue May 14, 2013 5:54 am |
JLACOUR
Joined: Wed Jan 14, 2009 8:18 pm Posts: 4915 Location: Lake Jackson, TX
Is the drawing of the proposed cutout close to actual size? If so, I think you have enough plate left to not cause integrity issues. Where's bayouboy??
Jesse 27 PD FPR 16x36 skiff - aka - DITCH WITCH
_________________ 37 PD EFI FPR 18x48 Tiller SOLD -- 36 PD EFI FPR 18x48 Stick Steer SOLD -- 27 PD FPR 16x36 Skiff
| Tue May 14, 2013 6:04 am |
Will
| Tue May 14, 2013 6:05 am |
banded-mallard
no, just to give an idea.
| Tue May 14, 2013 6:06 am |
Will
There's only 4 small bolts (13mm head and nut) holding the power head to that plate. Then there are the 4 big bolts holding the top plate to the bottom plate. Structurally, I don't think there will be an issue. The hole for the clutch will take out the middle but leave webbing between the bolts. When I get home today, I'll lay out the hole and snap a photo to get a better idea.
| Tue May 14, 2013 6:12 am |
Will
Those that are familiar know the two long bolts that hold the clutch still is how big that side of the clutch is, maybe not cur a straight clear path but big enough to be able to tilt the motor to get the front "lip" of the clutch out...
just thinking out loud right now.
| Tue May 14, 2013 6:14 am |
deadbird8
Step back a little:
1-How often will you be pulling the power head? 2-How much time will you spend modifying the plate with the potential of structural problems down the road? 3-Given 1 and 2 is it worth your time and the risk?
| Wed May 15, 2013 3:47 am |
Will
I'd pull it once a year if it were as easy as I want it to be just to clean out the tower and check things out. The first time I pulled it the splines on the collar was so rusted it had to be replaced. I put grease down there now on top of the upper tower seal to keep junk from building up directly on the seal..
As far as the plate, I'd get a new one cut and keep this one, if it ever gave a problem, just swap it back.
Thinking out loud...asking if anybody else ever thought about, will I do it? Probably not.
| Wed May 15, 2013 4:11 am |
