Back fire after gutted http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=41434 |
Author: | rudyeng [ Wed Jun 05, 2013 10:54 am ] |
Post subject: | Back fire after gutted |
Motor runs great. took bog out. Now backfires from WOT. What the hell do I do ?? |
Author: | DUCK HEARSE [ Wed Jun 05, 2013 10:58 am ] |
Post subject: | Re: Back fire after gutted |
got a leak some where |
Author: | forever draggin [ Wed Jun 05, 2013 10:58 am ] |
Adjust ur carb that's what I did |
Author: | banded-mallard [ Wed Jun 05, 2013 11:02 am ] |
When you gutted it, did you leave the stock outlet pipe? |
Author: | forever draggin [ Wed Jun 05, 2013 11:03 am ] |
Author: | rudyeng [ Wed Jun 05, 2013 11:30 am ] |
Yes I left the stock outlet pipe. Also turned the idle jets out to 2.5 turns. That removed the bog |
Author: | forever draggin [ Wed Jun 05, 2013 11:31 am ] |
Go some more |
Author: | rudyeng [ Wed Jun 05, 2013 12:01 pm ] |
past 2.5 turns on idle jet ? how much ? |
Author: | Buddy [ Wed Jun 05, 2013 4:34 pm ] |
How Far Did You Stick The Outlet Pipe Into The Can? |
Author: | rudyeng [ Wed Jun 05, 2013 4:46 pm ] |
I kept the original outlet pipe and just drilled additional holes inside the can. Breathes much better and throttle response is great but now it back fires. Also opened up the air idle to 3.5 turns. |
Author: | swamprat26 [ Wed Jun 05, 2013 4:56 pm ] |
Mine did the same. Head job fixed it. A head job is always the answer. Lol Sent from my iPhone using Tapatalk |
Author: | forever draggin [ Wed Jun 05, 2013 5:40 pm ] |
Author: | banded-mallard [ Thu Jun 06, 2013 4:40 am ] |
Author: | rudyeng [ Thu Jun 06, 2013 9:24 am ] |
Steady air stream coming behind this fitting. But I think its welded on the inside ? Could it be the cooling fan air or is this fitting leaking. How do you test it ? |
Author: | eljefe [ Thu Jun 06, 2013 12:24 pm ] |
you would know if its hot exhaust air .... most likely the cooling fan venting near there, prolly to help cool it. |
Author: | Team Camo [ Thu Jun 06, 2013 10:52 pm ] |
Yep, it's just the fan air. FYI, I ported that carb intake some also. Fatten it up a lil more. |
Author: | Mag10 [ Fri Jun 07, 2013 11:03 am ] |
Is it backfiring only when you rev and let off with no load. If so, that is pretty typical for these open exhausts. If it is still doing it when you rev and let off under load (prop in water) then worry about it. Mag10 |
Author: | rudyeng [ Fri Jun 07, 2013 3:51 pm ] |
Running great. Opened up the idle air mixture 3.5 turns. No bog. No backfire under load. Only backfires on land at WOT to zero. Problem is going away on its own. Motor is still breaking in. I think it's starting to run better. Thank you all ! |
