Home brewed muffler pics? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=41471 |
Author: | SCSuperfly [ Thu Jun 06, 2013 10:09 am ] |
Post subject: | Home brewed muffler pics? |
Gotta put together a muffler now and can"t make up my mind what I want it to look like. I think I'm gonna make it with two outlets but just can't make up my mind yet. Normally I only say this to girls but, "Show me your exhaust". |
Author: | OwenDickeson [ Thu Jun 06, 2013 10:16 am ] |
Post subject: | Re: Home brewed muffler pics? |
Copy the EVT |
Author: | CCC [ Thu Jun 06, 2013 10:18 am ] |
Did evt make the whole exhaust or did they buy a muffler and weld the flanges and outlets to make it fit a vanguard? |
Author: | Team Camo [ Thu Jun 06, 2013 10:20 am ] |
Author: | CCC [ Thu Jun 06, 2013 10:21 am ] |
So is it a muffler you can buy off the shelf? |
Author: | OwenDickeson [ Thu Jun 06, 2013 10:23 am ] |
No |
Author: | CCC [ Thu Jun 06, 2013 10:39 am ] |
They sure look like a car mufflerImageUploadedByTapatalk1370536740.026297.jpg |
Author: | Will [ Thu Jun 06, 2013 10:43 am ] |
Build on like BugsImageUploadedByTapatalk1370537023.823878.jpg |
Author: | Mag10 [ Thu Jun 06, 2013 11:17 am ] |
Mandrel bent primaries, separate chambers and outlets for each cylinder, drilled baffle plate with a deflector after it. All 304 SS Mag10 |
Author: | Bigrich [ Thu Jun 06, 2013 11:18 am ] |
Least u dont have to have to worry ab it rusting! |
Author: | Kmoppert [ Thu Jun 06, 2013 11:31 am ] |
Author: | banded-mallard [ Thu Jun 06, 2013 11:31 am ] |
IMG_1195.JPG IMG_1197.JPG |
Author: | Bigrich [ Thu Jun 06, 2013 11:41 am ] |
Author: | Bigrich [ Thu Jun 06, 2013 11:44 am ] |
Hard for something to rust that a magnet won't stick too |
Author: | Gameover [ Thu Jun 06, 2013 12:02 pm ] |
Build it out of a duplex stainless like 2205 and it won't rust even in salt water |
Author: | Gameover [ Thu Jun 06, 2013 12:04 pm ] |
Or if u just love spending money can alway go with 6moly can leave that on bottom of ocean for couple years and pull up with no rust |
Author: | Kmoppert [ Thu Jun 06, 2013 12:10 pm ] |
Author: | SCSuperfly [ Thu Jun 06, 2013 1:17 pm ] |
Hmmmmm........ The wheels are turning. |
Author: | dwight37 [ Thu Jun 06, 2013 1:23 pm ] |
The flanges coming off the motor are stainless but mufflers are not!! Gotta keeps kegs in business some how!! |
Author: | CCC [ Thu Jun 06, 2013 1:26 pm ] |
Author: | Bigrich [ Thu Jun 06, 2013 1:45 pm ] |
Rule of thumb from what I have always heard the higher the grade stainless the less mag. Draw it has so therefore mag won't stick. But never had an earth magnet. Normal use not including harsh chemicals won't make 304 rust or rot compared to the 400 series which is more corrosive resistant thin mild steel. But I was to vague in my comment. |
Author: | JIMMY W [ Thu Jun 06, 2013 1:45 pm ] |
Author: | dguidry [ Thu Jun 06, 2013 1:52 pm ] |
Make sure to dispose of contents before cranking her up: paint thinner muffler.jpg |
Author: | Team Camo [ Thu Jun 06, 2013 3:30 pm ] |
Author: | bayouboy [ Thu Jun 06, 2013 10:17 pm ] |
A lot of people don't know that stainless steel is actually rust resistant rather than totally rust proof, and can be damaged very easily by exposure to direct heat at high temperatures like in an exhaust system. Its actually an iron alloy that contains a minimum of 11.5 wt% chromium (which gives it that nice shine), but the carbon is what really gives it strength and the resistance to rust /or staining. The 304 when exposed to high temperatures is more susceptible to oxidation and color change. |
Author: | SCSuperfly [ Fri Jun 07, 2013 6:44 am ] |
Sounds like you did your homework Bayouboy. I believe you. |
Author: | Gameover [ Fri Jun 07, 2013 6:45 am ] |
The more carbon the more likely to rust. The molybdenum (MO) also referred to as moly the more corrosion resistance hence why I said a duplex 2205 which isn't much more expensive than 316 will hold up much much longer in a basic (saltwater ph ~ 8) environment and is twice as strong and 316 stainless. |
Author: | goodblasson [ Fri Jun 07, 2013 7:16 am ] |
Here is mine. 304SS sch 10 |
Author: | bayouboy [ Fri Jun 07, 2013 9:32 am ] |
Nice job! |
Author: | SCSuperfly [ Fri Jun 07, 2013 10:20 am ] |
Good work! |
Author: | Will [ Fri Jun 07, 2013 10:23 am ] |
Bet that thing warms up quick. |
Author: | med [ Fri Jun 07, 2013 10:29 am ] |
Author: | msm8281 [ Fri Jun 07, 2013 10:40 am ] |
Author: | bayouboy [ Fri Jun 07, 2013 12:22 pm ] |
