It is currently Sat Oct 10, 2026 10:45 pm
[ 6 posts ] |
shotgunwilly1117
Joined: Wed Aug 04, 2010 3:19 pm Posts: 345 Location: Tallahassee, Fl
 Gas line
Would it hurt performance on a motor to run a 3/8 inch tube from the gas tank and at the in line fuel filter change to 1/4 inch tube would it still draw the gas fine? I already have the tubing so if it would work it'd save me a lil money.
| Tue Jul 30, 2013 11:38 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: Gas line
if you have a electric fuel pump no..
but why?
_________________ I gave up mud motors
| Tue Jul 30, 2013 11:39 am |
shotgunwilly1117
 Re: Gas line
It's the copperhead 18, does it have a fuel pump? And just curious.
| Tue Jul 30, 2013 11:48 am |
banded-mallard
 Re: Gas line
| Tue Jul 30, 2013 12:50 pm |
cmiller73
Joined: Tue Jan 12, 2010 12:42 pm Posts: 2161 Location: Houma,LA
 Re: Gas line
_________________ Copperhead 12Hp SD on 1442 Alweld
| Tue Jul 30, 2013 2:51 pm |
Puddle jumper
Joined: Fri Jan 20, 2012 11:56 pm Posts: 98 Location: Abita Springs, LA
 Re: Gas line
If your running 8 to 10' of line your fine with the 3/8", if your running any more than that you'll have starvation issues at 3700-3800 rpm meaning you will not turn the 4000-4100 you should be. The problem with the 3/8" line is the amount of weight the pump has to pull from the front of the boat, by dropping to 1/4" line you reduce the amount of fuel weight and still turn proper rpm.
| Tue Jul 30, 2013 5:56 pm |
[ 6 posts ] |
