It is currently Fri Oct 09, 2026 7:34 pm
Reply to topic  [ 11 posts ]
 Stock carb adapter for k&n
Post Stock carb adapter for k&n
Is there any gain from doing this with the cone k&n. I still have my stock airbox with stock filter (minus foam prefilter).
Tue Jul 30, 2013 12:49 pm
Post Re: Stock carb adapter for k&n
no just look cool :lol:
I gave up mud motors
Tue Jul 30, 2013 1:15 pm
Maybe if you can find one for a 32 it may fit a round filter like you want. Not quite sure..im sure somebody tried it..
Tue Jul 30, 2013 2:04 pm
gecker used to make one..
brads has one
Tue Jul 30, 2013 2:49 pm
Pull your air cleaner cover off and see if you pick up any rpms. I picked up 120. I drilled my stock air cleaner cover. On a inboard it doesn't get dirty like on a sd. Pulling the air cleaner with the cover removed equalled zero gains. The cover was my limiter.
Tue Jul 30, 2013 2:53 pm
I think al has one. My dad is running one they sell for kohlers on his 32.
With a couple other small things done to the carb, I think it helps. I ran the donaldson adapter on mine.
Tue Jul 30, 2013 2:55 pm
The stock filter is good for up to ~240hp...Thats without the cover on. Not sure if cover limits that. But the filter media can flow that much.
Tue Jul 30, 2013 3:06 pm
Disclaimer : my results were not on a stock motor
Tue Jul 30, 2013 3:08 pm
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
I've seen it before. It made for the old Donaldson air filter I believe. But does it add value or it is a waste of time.
Tue Jul 30, 2013 5:16 pm
I have the said 32hp carb and would love to get off of it cheap if any interest. PM me.
Modded 36 PD draggin' around an 1848 PD boat backwards!
Wed Jul 31, 2013 10:56 am
