It is currently Thu Oct 08, 2026 1:20 pm
Reply to topic  [ 14 posts ]
 Heads....
Post Heads....
Might as well work the extra set I have.
Modded 36 PD draggin' around an 1848 PD boat backwards!
Thu Aug 01, 2013 10:09 am
Post Re: Heads....
I have 12 sets to do
Thu Aug 01, 2013 10:10 am
Post Re: Heads....
Def would use kirt vice befor clamping on table directly Hope you indicated them as we'll
Thu Aug 01, 2013 10:12 am
Post Re: Heads....
A vice sure would have been easier. Had better luck clamping to the table than I did with the vice. Plus I didn't want to do one at a time. I guess I could have put two vices on the table side by side but just figured that'd be even more set up time.
Thu Aug 01, 2013 10:19 am
Post Re: Heads....
True done once done right
Thu Aug 01, 2013 10:34 am
Post Re: Heads....
Good lil set up
Thu Aug 01, 2013 10:35 am
Post Re: Heads....
Cut these .040. Great finish with slow feed and high speed. Also when done ran the heads over 600 grit on the rock (granite) table. Now I just have to port and polish.
Thu Aug 01, 2013 10:40 am
Post Re: Heads....
Thu Aug 01, 2013 10:42 am
Post Re: Heads....
Nice. That'll do it. These heads have zero hours on them so I am only gonna lap the valves in. Probably throw in some ss valves and a 3 angle valve job when they get some time on them. Gonna let one of my buddies run these on a stock motor. Should bump up his load carrying capabilities pretty good.
Thu Aug 01, 2013 10:48 am
Post Re: Heads....
Yea mine are decked .035 stainless valves and laped And port and polish Lots or extra power
Thu Aug 01, 2013 11:33 am
Post Re: Heads....
What bouts y'all find the ss valves to put in them?
Thu Aug 01, 2013 11:34 am
Post Re: Heads....
Thu Aug 01, 2013 11:37 am
Post Re: Heads....
You mean pvt?
Thu Aug 01, 2013 11:38 am
Post Re: Heads....
Thu Aug 01, 2013 11:44 am
