It is currently Thu Oct 08, 2026 1:20 pm
Reply to topic  [ 14 posts ]
 PD Cam
Post PD Cam
How hard is it to install a new BPS Cam in my 08 PD? I shaved my heads with no problems and I was woundering if I really need to bring it to someone or is it something I can do myself!!!
36HP Prodrive W/
Mods
18'X48" Prodrive Haul
Thu Jul 04, 2013 10:49 pm
Post Re: PD Cam
Gotta pull the block off the frame for starters.
35 GTR - 1754 Extreme
Fri Jul 05, 2013 8:04 am
Post Re: PD Cam
Not bad, take ur time and u will be ok. Do it easy in a day...
Fri Jul 05, 2013 12:23 pm
Post Re: PD Cam
An 08 might give you a little trouble. some motors that old don't like to come apart. If you took care of it and sprayed it down with WD40 or some sort of corrosion inhibitor on a regular basis than you should be fine. Some times the clutch and spine adapter can be a bitch to get off. I'd soak the down now.
Also its a good idea to go ahead and get new PTO oil seal. Remove the old one before pulling the crank case/sump so that you can clean the rust off the PTO/crank shaft before dragging it across your bearings.
There's more but my lunch is getting cold.
Fri Jul 05, 2013 12:44 pm
Post Re: PD Cam
I helped my buddy change his clutch the other day and I soak my motor in WD-40 everytime I use it so I should be fine. Where is a good place to get a cam?
36HP Prodrive W/
Mods
Fri Jul 05, 2013 2:29 pm
Post Re: PD Cam
All depends on what you want your motor to do?
Fri Jul 05, 2013 2:54 pm
Post Re: PD Cam
Fri Jul 05, 2013 8:15 pm
Post Re: PD Cam
Fri Jul 05, 2013 10:03 pm
Post Re: PD Cam
36HP Prodrive W/
Mods
Fri Jul 05, 2013 11:00 pm
Post Re: PD Cam
Sat Jul 06, 2013 3:45 am
Post Re: PD Cam
:lol: dats right!
Mon Jul 08, 2013 4:59 pm
Post Re: PD Cam
Mon Jul 08, 2013 7:03 pm
Post Re: PD Cam
:lol: @ sardines
Mon Jul 08, 2013 8:13 pm
Post Re: PD Cam
Well did you do it?
Thu Aug 01, 2013 1:37 pm
