11Bravo
 PD 36 stock muffler
Does anyone have the part number for a stock Briggs muffler? I want to keep a spare on hand. Thanks much, Wayne
Thu Aug 08, 2013 3:43 pm |
Bug
Joined: Sat Oct 29, 2011 10:28 am Posts: 1068 Location: Tallahassee, Fl
 Re: PD 36 stock muffler
Got one a while back from MB cheap. They site will show if they have any stockers on hand
_________________ PRODRIVE 1860 CC "Let the good times roll" Luck??? The bassards don't stand a chance!
Sun Aug 11, 2013 1:00 pm |
dirtybird29+
Joined: Mon Feb 15, 2010 8:03 pm Posts: 393 Location: South Carolina
Just remember if it comes off a horizontal motor The outlet will be pointing down if installed on a vertical motor like a pd
Sent from my iPhone using Tapatalk 2
_________________ 1854 GTB Extreme 35GTR
Sun Aug 11, 2013 4:39 pm |
Bug
yep didnt cause any issues though
Sun Aug 11, 2013 7:29 pm |
banded-mallard
I was told it will bolt up but the outlet will be pointing straight down. Might be able to weld a 90 on it to turn it toward back. Great price though.
Mon Aug 12, 2013 5:16 am |
Buddy
Joined: Mon Aug 06, 2012 9:06 am Posts: 579 Location: Tallahasse, FL
They are a little better quality that the stock PDs.
_________________ 1754 XSeries Kawi Powered PRODRIVE ...
Mon Aug 12, 2013 7:57 am |
banded-mallard
You have one?
Mon Aug 12, 2013 10:22 am |
barnes_53
Call the Boat Dr. in Harahan
He sells stocks that are take-offs when he does engine mods.
Mon Aug 12, 2013 10:34 am |
Buddy
Mon Aug 12, 2013 10:36 am |
banded-mallard
But I have recently bought the hydro reverse kit and I don't have the room to install the Hydro ram, exhaust it too tight of fit. IMG_1556.JPG
So I'm either gonna make another one, or buy a stock one and gut it. The sotck one will already give me the clearance for the ram, so alittle less fab work.
You have any picks of it? How did you manage the outlet pipe sticking straight down?
Mon Aug 12, 2013 11:55 am |
Buddy
I will get you some pics. But I got a 1-1/2" 90 from all purpose pipes toned it down some. you can't beat the price and you can gut one in a few hours.
Mon Aug 12, 2013 2:49 pm |
Buddy
The only bad thing about the MB muffler is the outlet pipe is welded to the other side of the can. So to get the guts out you have to cut a hole in the side of the muffler and then patch it. The 90 helps keep the sound from bouncing off the water. I rolled a piece of 16 ga 304 SS and welded it to the bottom. It keeps the outlet pipe from falling out from all the vibrations.
Tue Aug 13, 2013 4:49 am |
banded-mallard
Thats not bad at all. My outlets were 1.5" 45's. I was gonna gut it anyway and weld the outlet pipe in it. I mainly needed the header offset so the ram would fit. I have everything to make another, just no time right now. So you basically put a weld pad around the pipe. Welded the plate to exhaust and ran outlet pipe through both.
Tue Aug 13, 2013 5:18 am |
Buddy
Yea, I took a hole saw and cut a hole in the plate and welded I out all the way around. I have had 2 vibrate and break the can. This should solve that problem.
Tue Aug 13, 2013 6:22 am |
11Bravo
Tue Aug 13, 2013 9:56 am |
Buddy
Tue Aug 13, 2013 2:47 pm |
11Bravo
Wed Aug 14, 2013 1:19 pm |
