RPM Question
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=44535
Author:  JLACOUR [ Thu Aug 22, 2013 11:33 am ]
Post subject:  RPM Question
So when I'm cruising, let's say I'm at 95% throttle, I'm turning around 4200 to 4250 rpms. But when I open up to 100% throttle, my rpms drop to 4100 to 4150.
Is it starving? Could the governor be the problem even though at one point it turns up higher?
Here is a rough chart to help illustrate what I'm talking about.
Stock 27 Kohler.
Author:  bayouboy [ Thu Aug 22, 2013 11:46 am ]
Post subject:  Re: RPM Question
Because its going up hill!
Author:  JLACOUR [ Thu Aug 22, 2013 11:51 am ]
Well shouldn't it pick back up on the down side???
Author:  bayouboy [ Thu Aug 22, 2013 11:58 am ]
Um I never seen a mudboat do down hill! lol
Lost velocity, jetting. How close are you to hitting the governor at wot.
Author:  JLACOUR [ Thu Aug 22, 2013 1:14 pm ]
Governor is around 4600 neutral.
Author:  BlueShamu [ Thu Aug 22, 2013 1:22 pm ]
Is this something that just started or has it always been this way?
Can you make it repeat this response in neutral, out of water?
Initially, sounds like you are hitting a rev limiter?? Mine will drop to 3600 once I hit the 4350 mark.
Author:  Will [ Thu Aug 22, 2013 1:25 pm ]
Author:  JLACOUR [ Thu Aug 22, 2013 2:21 pm ]
Author:  JLACOUR [ Thu Aug 22, 2013 2:23 pm ]
Author:  richard nagon [ Thu Aug 22, 2013 5:15 pm ]
your gov. has no idea if its carrying one delta or three deltas.
Author:  JLACOUR [ Thu Aug 22, 2013 5:27 pm ]
Author:  tchauvin [ Thu Aug 22, 2013 5:38 pm ]
Did you ever do a plug check at WOT? May be going lean at WOT. Easy way to check, pull choke lever in small increments if possible when at WOT see if rpm rises.
Author:  richard nagon [ Thu Aug 22, 2013 5:44 pm ]
here is something to try set gov. back to 3600 rpms and do another run test. get back to me. do it with a no load in boat.
Author:  JLACOUR [ Thu Aug 22, 2013 5:49 pm ]
Author:  JLACOUR [ Thu Aug 22, 2013 5:52 pm ]
Author:  richard nagon [ Thu Aug 22, 2013 6:30 pm ]
first of all set ur carb at wot. with ur throttle cable not any further. than set ur gov at lets say 4000-4100 rpms. and see what happens.
