It is currently Mon Dec 15, 2025 9:49 pm
[ 9 posts ] |
low idle after adjusting valves
MuddyPat
Joined: Sat Aug 20, 2011 2:30 pm Posts: 70 Location: St. Louis
Ive been slacking on setting my valves. Its been about 50 hrs since I last adjusted. I set both valves one side at a time, 1/4" past TDC on the compression stroke to .004 with the motor cold. Its kind of a pain to find that 1/4" past point. Its kind of a clunk when the piston starts to drop back down which im guessing is the cam (right?). Hope im doing this correct. Anyway, i got her all put back together, fired it up and the idle is very low (750rpm). it wants to die if i don't stay in the throttle. Is it possible i set the valves wrong or too tight? Or do i just need to adjust the idle?
_________________ GTR 35 Cdi
| Fri Sep 06, 2013 8:11 pm |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
 Re: low idle after adjusting valves
.004 cold is a little tight if you ask me, try setting them .006-.007 cold and see if it helps. I adjust mine the way you did, others do it there way. To each their own I guess as long as it works.
| Fri Sep 06, 2013 8:37 pm |
MuddyPat
I think briggs calls for .004-.006. Am i better off on the .006 side to be safe. And it sounds like a ridiculous question but when you turn the motor with the plugs out, is there a more exact way to get it to the 1/4" past TDC than turning the prop by hand. Not that it is hard to turn, just doesn't seem smooth
| Fri Sep 06, 2013 9:13 pm |
BayouBuster
That's the easiest way, Once you do it a time or two You'll get the feel for it.
| Sat Sep 07, 2013 3:18 am |
Mudmotor Slayer
Do it at topdead center and set both
| Sat Sep 07, 2013 3:39 am |
MuddyPat
at TDC or 1/4" past
| Sat Sep 07, 2013 5:26 am |
SCSuperfly
I read the same stuff everybody else does and set both of mine 1/4" past tdc on a compression stroke. Worked out good so far. I don't get the 1/4" past tdc? ??? It works though.
_________________ Modded 36 PD draggin' around an 1848 PD boat backwards!
| Sat Sep 07, 2013 8:19 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
_________________ I gave up mud motors
| Sat Sep 07, 2013 8:30 am |
banded-mallard
| Sun Sep 08, 2013 7:12 am |
[ 9 posts ] |
