Oil filter #'s
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=46207
Page 1 of 2
Author:  pokey79 [ Wed Oct 09, 2013 11:53 am ]
Post subject:  Oil filter #'s
Briggs 842921
Fram PH8170
Wix 51056
Purolater L35310
Baldwin B1410
Napa. 1056
Was bored and starting cross reference and this is what I came up with so I thought I would share!!
Author:  3rd Coast Killer [ Wed Oct 09, 2013 12:12 pm ]
Post subject:  Re: Oil filter #'s
I have a WIX number of 57035??
Thanks for the good info. I only had the brigs, wix and Fram numbers.
Author:  dirtybird29+ [ Wed Oct 09, 2013 1:27 pm ]
Author:  SCSuperfly [ Wed Oct 09, 2013 1:36 pm ]
I'm running a Frame PH3614.
Author:  BayouBuster [ Wed Oct 09, 2013 2:00 pm ]
I run WIX 51348.
Sent from my iPhone using Tapatalk -
Author:  pokey79 [ Wed Oct 09, 2013 3:09 pm ]
If u go to frams site and put in briggs filter number u get the fram number then use frams number on wix site and so on!!
Author:  Barroll [ Wed Oct 09, 2013 4:47 pm ]
I am running a Briggs 492932. Is this the correct filter I need? I told them a briggs 35 vanguard at the mower shop and that is what they handed me.
Author:  mizzippi jb [ Wed Oct 09, 2013 6:10 pm ]
If it screws on and seals it works.
Sent from my GT-P5113 using Tapatalk 2
Author:  Will [ Wed Oct 09, 2013 6:19 pm ]
Author:  pokey79 [ Wed Oct 09, 2013 6:29 pm ]
The briggs number I posted is the one that came on both of my 35's brand new and the diffrence would have to be what pressure the relief valve opens at in the filter!!
Author:  Will [ Wed Oct 09, 2013 6:41 pm ]
I'll look tomorrow but somewhere I found where the Briggs number you posted and the other are the same.
Author:  Will [ Wed Oct 09, 2013 6:46 pm ]
Maybe the 4 is a short and the 8 is the tall
Author:  Will [ Wed Oct 09, 2013 6:47 pm ]
Check this out ...http://www.buggiesgonewild.com/big-bloc ... riggs.html
What do you think?
Author:  p5388 [ Wed Oct 09, 2013 6:56 pm ]
Parts Master ("house brand" for many NON-Mega chain auto parts storts) 61348 is made by Wix, but carries around a $3 price tag - Replacement for Kohler and Briggs...
also:
BRIGGS & STRATTON/492932S
Stens Part 120-485 - OIL FILTER. Replaces OEM: BRIGGS & STRATTON, 492932S, KAWASAKI, 490657007, JOHN DEERE, AM125424, TECUMSEH, 36563, HUSQVARNA, 531307389, GRASSHOPPER, 100803, BOBCAT, 4164537, BAD BOY, 063200400, BRIGGS & STRATTON, 696854, BRIGGS & STRATTON,842921 , CRAFTSMAN, 24603, BRIGGS & STRATTON, 492932B, E-Z-GO, 492932S, KAWASAKI, 490652077, KAWASAKI, 490652071, TORO, 1077817, CRAFTSMAN, 33935, BRIGGS & STRATTON, 4049, BRIGGS & STRATTON, 4049H, BRIGGS & STRATTON, 5049H, BRIGGS & STRATTON, 695396, BRIGGS & STRATTON, 492932, BRIGGS & STRATTON, 492056, BRIGGS & STRATTON, 4154, KOHLER, 2505001, HUSQVARNA, 531307043, BRIGGS & STRATTON, 5049, BRIGGS & STRATTON, 5076, JOHN DEERE, GY20577, JOHN DEERE, LG492932S, KAWASAKI, 490657002, KAWASAKI, 490652076, JOHN DEERE, LG4153, JOHN DEERE, AM119567, KAWASAKI, 490652057 Fits Models: BRIGGS & STRATTON, Vanguard engines small version filter; for 12thru 25 HP engines; pressure lubrication engines, E-Z-GO, ST480, GRAVELY, XL Series, JOHN DEERE, F620, F680, F687, M653, M655, M665, Z245, Z425, Z510A, Z520A, Z910A and Z920A ZTrak mowersand lawn tractors, 1200 Hydro Rake, 800 Aercore Aerator, KAWASAKI, FB460V, FC420V, FC540V, FD501D, FD590V, FR651V, FR691V, FR730V, FX481V, FX541V, FX600V, FX651V, FX691V and FX730V, KOHLER, CH18-CH25 and CV18-CV25; for 18 thru 25 HP engines, LIEBHERR, Loader L507 with Deutz BF4L1011FT engines, TECUMSEH, OHV130, OHV135, OHV150, OHV155, OHV165, OHV175, OHV180, TVT691, OV and VTX, TERRAMITE, Roller Paver with Briggs and Stratton Vangaurd; T5C loader with Briggs and Stratton 18hp IC. Used By: Available in our 120-483 Oil Filter Shop Pack (12), Available in our 785-521 Engine Maintenance Kit, Available in our 785-525 Engine Maintenance Kit Specs: 3" , OD, 2 1/4" , Height, 28, Micron, 3/4" -16, Thread Size, 7-9 PSI pressure relief , Anti-drain
Author:  pokey79 [ Wed Oct 09, 2013 6:56 pm ]
thanks will u found me the number I was searching for K&N HP-1002
Author:  JLACOUR [ Wed Oct 09, 2013 6:59 pm ]
^ that's the same as kohler...
Mobil 1 = M1-102 and Wix 51348
Author:  dillakilla12 [ Thu Oct 10, 2013 6:08 pm ]
Ok Im an idiot...but Im gonna ask. The big block motors take the same filter as the small blocks? Like would my 23 take the same as a 35?
True dat!!
Author:  diddyduck [ Thu Oct 10, 2013 6:28 pm ]
Author:  270Handiman [ Thu Oct 10, 2013 7:03 pm ]
I didn't know it was this damn complicated, lol. I just go to Home Depot and buy a Briggs filter. Done.
Author:  tman52804 [ Thu Apr 16, 2015 9:44 am ]
I just bought a Briggs 492932S for my 35 and I am not going to use it, it doesn't have the check valve.
Careful when reading the cross's above, it must have the check valve. If you look in the filter you can see the spring in my 842921, not there in the 492932S
OHV motors need pressure up top, hence the valve.
Author:  cb5331 [ Thu Apr 16, 2015 11:47 am ]
The wix and napa have a check valve, so does the k&n
Author:  ksgoosekillr [ Thu Apr 16, 2015 11:59 am ]
Highly recommend the K&N, if you have every had to punch a screw driver thru an oil filter to remove it you will understand why I like the K&N design that has a built in hex.
Author:  nuccifish06 [ Thu Apr 16, 2015 12:43 pm ]
Author:  CJB [ Thu Apr 16, 2015 12:47 pm ]
Author:  baron von [ Thu Apr 16, 2015 12:55 pm ]
i thought the "check valve" was to hold oil in the filter after shut down, and some have a by-pass that by-pass the filter element if the filter is plugged?
Author:  CJB [ Thu Apr 16, 2015 1:02 pm ]
Great questions...these are all great questions...
Author:  baron von [ Thu Apr 16, 2015 1:12 pm ]
Author:  HOTSAUCE170 [ Thu Apr 16, 2015 3:26 pm ]
Author:  msm8281 [ Thu Apr 16, 2015 3:37 pm ]
I'm sure Briggs doesn't make their own filter and buys from a 3rd party. Just like the Briggs oil that they slap a sticker on.
Author:  baron von [ Thu Apr 16, 2015 4:54 pm ]
Author:  HOTSAUCE170 [ Thu Apr 16, 2015 6:16 pm ]
On small engines yes
Sent from denda this
Author:  HOTSAUCE170 [ Thu Apr 16, 2015 6:17 pm ]
Author:  tman52804 [ Fri Apr 17, 2015 1:36 pm ]
I know I physically looked at both the Wix filters, 51348 & 57035 and they have the check valve.
The 57035 is identical in size to the factory filter. I chose the 51348 because it was black in color and slightly longer, giving me more filter area.
Author:  HOTSAUCE170 [ Fri Apr 17, 2015 1:46 pm ]
This may help with the anti drainback/check valve and pressure relief
Author:  baron von [ Fri Apr 17, 2015 8:44 pm ]
hey I got a BS and a Stens filter on the drain rack now - if I get around to it i'll saw off their tops to compare inards tomorrow
Author:  msm8281 [ Fri Apr 17, 2015 8:58 pm ]
Author:  baron von [ Sat Apr 18, 2015 7:58 pm ]
OK by popular demand here is 3 common engine filters dissected, from left to right B/S, Stens, NAPA gold,
Author:  msm8281 [ Sat Apr 18, 2015 8:06 pm ]
So the Napa gold looks better.
Author:  baron von [ Sat Apr 18, 2015 8:14 pm ]
it actually did, better quality looking filter element and larger filter area, the drain back seal was more pliable and larger, the filter by pass better - this is the filter I use on my 19 kawi lawn mower, it's a little smaller sealing surface but gasket should seal on vanguards
Author:  cb5331 [ Sat Apr 18, 2015 9:14 pm ]
Thanks.
Page 1 of 2 All times are UTC - 6 hours
