| Leak down values? Modded motor not producing a lot of power http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=47113 |
Page 1 of 2 |
| Author: | shooter [ Wed Nov 06, 2013 1:17 am ] |
| Post subject: | Leak down values? Modded motor not producing a lot of power |
Performed a leak down test on my newly rebuilt motor tonite, not sure what values are acceptable but I was a little disappointed to see the results. Cyl #1 was about 25%, cyl #2 was about 20%. These are in the green zone on the gauge, but seem high to me. Test was done with 15 PSI input. Sounds like the leakage is on the intake side. The motor has heads decked .045, shaved pistons, EVT cam. New stock springs shimmed .060. MM exhaust. Mikuni HSR42 carb, freshly rebuilt, with K&N filter and EVT stainless intake. I had lapped all valves prior to assembly, compression is 175 & 178 PSI. Valves have been set both for .005" at both intake and exhaust, and also .004 intake, .006 exhaust, 1/4" past TDC. Coil gap set to .006. This motor is just not performing as I hoped it would after mods. Right now, in addition to not producing much more power than stock, the #1 cyl is running so rich it's fouling the plug and the #2 cyl is running lean enough to cause the exhaust to glow on that side. I originally had major intake air leaks, I cut my own intake gaskets and sealed with Permatex aircraft gasket dressing, still seeing red exhaust #2 side only. I installed new coils the end of last season, and a spark checker indicates spark is healthy thru the operating range. I just replaced the #1 spark plug but haven't run it since. Man, I sure could use some advice at this point. What else can I check? Any thoughts about what's wrong? |
| Author: | Will [ Wed Nov 06, 2013 5:53 am ] |
| Post subject: | Re: Leak down values? Modded motor not producing a lot of po |
Was #1 oil or gas fouled? Bad head gasket or piston rings ? |
| Author: | renovator [ Wed Nov 06, 2013 6:08 am ] |
Piston rings may be in upside down. Some rings are have a taper they recently switched to square edge ring. May still have an air leak. From what I was told and read those leak down numbers are not that bad ,typical for a stock motor |
| Author: | diddyduck [ Wed Nov 06, 2013 6:22 am ] |
not sure how big of a deal it is but from what ive read i thought a leak down test was done with 90-100 psi |
| Author: | immoody [ Wed Nov 06, 2013 6:38 am ] |
15 psi for a leak down test is quite low. Most people use 80-100 psi for a leak down test. Did you remove loosen the rocker arms when performing the leak down test? With more air pressure it will be easier to hear where leak is coming from. With one cylinder being rich and the other lean it could possibly still be an intake leak. An intake leak will affect the air/fuel mixture. |
| Author: | Jamie B. [ Wed Nov 06, 2013 7:44 am ] |
Did I read that you have shaved piston, longer rods, Heads Decked .045, and your compression is 175? Something is not right if this is the results. |
| Author: | renovator [ Wed Nov 06, 2013 10:09 am ] |
^^. The masters eye. My heads are decked .015 with the pistons and I'm at 240psi ,maybe the rods are stock length. |
| Author: | Will [ Wed Nov 06, 2013 11:04 am ] |
240!? |
| Author: | dfou [ Wed Nov 06, 2013 11:15 am ] |
| Author: | Will [ Wed Nov 06, 2013 11:18 am ] |
| Author: | Jamie B. [ Wed Nov 06, 2013 11:20 am ] |
Why would you install shaved pistons with stock length rods? |
| Author: | Will [ Wed Nov 06, 2013 11:21 am ] |
I wouldn't |
| Author: | Jamie B. [ Wed Nov 06, 2013 11:22 am ] |
Maybe I shouldn't of assumed. |
| Author: | renovator [ Wed Nov 06, 2013 11:25 am ] |
| Author: | Jamie B. [ Wed Nov 06, 2013 11:28 am ] |
I was about to ask how in the hell it went up 20 PSI.lol |
| Author: | renovator [ Wed Nov 06, 2013 11:49 am ] |
| Author: | shooter [ Wed Nov 06, 2013 1:34 pm ] |
| Author: | Jamie B. [ Wed Nov 06, 2013 3:03 pm ] |
Are you holding the throttle wide open when performing the comp test? The stock gaskets are fine, but not the problem. Depending on you block measurement you should be around 235-250 with those mods, unless some how you got the stock length billet connecting rods with stock pistons, It could happen. |
| Author: | shooter [ Wed Nov 06, 2013 3:53 pm ] |
Yes, throttle is WO when checking compression. Not sure about rod length, but if I recall the top of the piston pretty much comes flush with the face of the cylinder. Not sure what that means, or if the difference in lengths would be obvious? |
| Author: | pokey79 [ Wed Nov 06, 2013 4:13 pm ] |
Hmmmmmmm?? |
| Author: | Jamie B. [ Wed Nov 06, 2013 4:29 pm ] |
To me without measuring and putting my hands on the motor, those numbers that is stock length rods with stock pistons. Now, to fix you power problem I read that you used cork gaskets from the intake to head? The cork gasket will burn rather quickly and develop a leak at the intake |
| Author: | dfou [ Wed Nov 06, 2013 4:35 pm ] |
Try a different compression tester. I had on quit on me the other day Sent from my iPhone using |
| Author: | Jamie B. [ Wed Nov 06, 2013 4:42 pm ] |
| Author: | shooter [ Wed Nov 06, 2013 6:18 pm ] |
| Author: | Jamie B. [ Wed Nov 06, 2013 6:22 pm ] |
With out measuring the rod it self there is no way that I know of telling what rods you have. |
| Author: | Jamie B. [ Wed Nov 06, 2013 6:24 pm ] |
Can you take a picture of your sparks plugs after you run them? |
| Author: | Jamie B. [ Wed Nov 06, 2013 6:30 pm ] |
When you installed them, did the depth in the dish of the pistons look the same as the stock dish? |
| Author: | pokey79 [ Wed Nov 06, 2013 6:36 pm ] |
Jamie let me know what the id is on the rods for the crank and then I can tell y'all if the rods are the same length from the picture |
| Author: | cupped up [ Wed Nov 06, 2013 6:59 pm ] |
Jamie, what's the deck height on a stock 31? If its like the 35, stock deck height is around 60 thousandths I think. Him running shaved pistons and aftermarket rods and the piston coming flush to the deck, it's gotta be longer rods or the pistons have a taller compression height, which should in the end end up with more than 180 Psi compression right? Unless the stock deck height on the 31 is different, I know the stroke is. Just trying to brainstorm. |
| Author: | cb5331 [ Wed Nov 06, 2013 7:07 pm ] |
| Author: | cupped up [ Wed Nov 06, 2013 7:11 pm ] |
I thought shooters motor was a 32 it never specified above tho |
| Author: | cb5331 [ Wed Nov 06, 2013 7:13 pm ] |
Just going out on a limb here, but wouldn't the rods for a short stroke motor be longer than those for a motor with a longer stroke? So going to a longer rod for a long stroke might still be too short for the short stroke. |
| Author: | cupped up [ Wed Nov 06, 2013 7:20 pm ] |
| Author: | cb5331 [ Wed Nov 06, 2013 7:22 pm ] |
Same block, same bore, different stroke. I know that for sure. The 31/32 is a short stroke motor. |
| Author: | cupped up [ Wed Nov 06, 2013 7:24 pm ] |
If that was the case, the pistons wouldn't be close to flush with the deck like he said, right? 3.07 is the 32 stroke and 3.41 is the 35 stroke. A .120 longer rod for the 35 in a 31 doesn't seem like it'd be close to coming flush with the deck, would it? |
| Author: | cb5331 [ Wed Nov 06, 2013 7:25 pm ] |
I don't know, but sure seems like a good way to loose 70 psi. |
| Author: | cupped up [ Wed Nov 06, 2013 7:26 pm ] |
Wurd! |
| Author: | Jamie B. [ Wed Nov 06, 2013 7:45 pm ] |
The deck height on the 31 I have was a lot closer to 0 deck height than a 35( i don't remember exact measurements). This would make sense if he had a 32 HP motor with stock length rods and pistons. If this is the case his compression numbers are pretty much dead on at .045 head decking. The 31/32 has the same block and shorter stroke on the crank, the means the the rods are longer on the shorter stroke( Reason the 31with .080 oversize bore was one of Drake 1 favorite motors). The 35/36 has a longer stroke crank with the shorter rod. |
| Author: | shooter [ Wed Nov 06, 2013 7:57 pm ] |
SHIT! Once again, the obvious bites me in the ass. I swear, some times I get so caught up in details I miss the big picture. Yes, this is a 32 motor. So... can I just get some aftermarket rods for a 32 and get right? |
| Author: | renovator [ Wed Nov 06, 2013 7:59 pm ] |
Or get a crank for a 36. If I'm correct |
| Page 1 of 2 | All times are UTC - 6 hours |
