BadBowtie
Joined: Wed Jan 14, 2009 5:04 pm Posts: 268 Location: Mt. Vernon, IN
 Bent cavitation plate 36 pd
Slightly bent the cav plate this weekend. Whats the best way to fix? Take it off the lower unit and bend back? It is just flared up on one side where it is welded to the vertical piece that bolt to lower unit.
_________________ 1848 GTB, 36 PD w/ FPR
| Mon Nov 11, 2013 11:38 am |
BadBowtie
 Re: Bent cavitation plate 36 pd
Got it fixed with a dead blow
Sent from my iPhone using
| Mon Nov 11, 2013 7:08 pm |
BlueShamu
Joined: Mon Feb 06, 2012 6:13 pm Posts: 5605 Location: D'town, LA
Don't mean to hijack the thread...but...Are the cavitation plates really needed for the PD...except to keep your prop from hitting your transom when using FPR?? I've always wondered about that....and there has to be some people out there that have played with taking the cavitation plate off and/or modifying the cavitation plate.
| Mon Nov 11, 2013 8:01 pm |
NORTHFLORIDAFOWLER
Joined: Sun Mar 11, 2012 9:00 pm Posts: 1239 Location: South, Ga/North Fl
I don't have one on mine the bitch just vibrates off
| Mon Nov 11, 2013 8:39 pm |
NORTHFLORIDAFOWLER
Bolts always fall out even with lock tite
BlueShamu
| Mon Nov 11, 2013 8:48 pm |
NORTHFLORIDAFOWLER
ive given up lol you cant keep those top 2 in there for crap, the threads are all wallered out now from the excessive vibration.
| Mon Nov 11, 2013 10:03 pm |
banded-mallard
| Tue Nov 12, 2013 5:38 am |
Will
I know for a FACT a bad prop with fuck one up. After it works loose once, like NFF said, the holes get mess up and makes it harder to keep them tight, I think the thing to do is run a small bead of silicone in the groove and put it back on. Then it'll be there and have some vibration isolation but you can get it off later if needed with a little pulling.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Tue Nov 12, 2013 5:45 am |
BadBowtie
Hmm interesting guys. All looks ok now and I will check the bolts. Pretty sure I hit something hard. Lake is veeeeerrrryyy low this year.
Will head back out with it nov 30, until then time do get some deer in the freezer
| Tue Nov 12, 2013 8:32 pm |
