It is currently Wed Oct 21, 2026 11:01 pm
[ 5 posts ] |
35 gtr Clutch Smoke in reverse
rudyeng
Stuck to Chit last week and I guess I did not hold the reverse lever hard enough. Clutch smoked for a few seconds. Turned off motor for 10 minutes. Put it in forward works fine
What do I need to inspect to make sure clutch is ok ?
Thank you.
| Fri Nov 29, 2013 4:03 pm |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
 Re: 35 gtr Clutch Smoke in reverse
Take off clutch cover, look for debri, its card to inspect clutch without taking apart.
Sent from my DROID RAZR using Tapatalk
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
| Fri Nov 29, 2013 4:25 pm |
cupped up
Joined: Tue Jun 05, 2012 7:25 pm Posts: 4205 Location: St. Amant, LA
Probably wasn't the clutch smoking...reverse has nothing at all to do with the clutch. Don't you have the 3rd gen caliper? They're junk, pads slip too much. Probably the pads smoking. You're probably fine just inspect the pads for heat damage and the rotor...then roll with it.
| Fri Nov 29, 2013 7:11 pm |
DmaxHunter
Didn't even see reverse in my tapatalk, cupped up is right sounds light pads, i had to go to a different caliper setup on mine.
| Fri Nov 29, 2013 7:20 pm |
Brady
Your clutch is not smoked at worst it will cost you 130 bucks for new rotor and break pads .
_________________ 17/54 gator tail extreme with a stage 2 gator tail strapped on the back
viewtopic.php?f=5&t=43412
| Sat Nov 30, 2013 9:00 am |
[ 5 posts ] |
